FixYa.com
Tags:
Compaq FS 7550 17 in.CRT Conventional Monitor
Horizontal Bright White Line in Middle of...
posted by jammer2552 on Nov 10, 2007
Here's what happened. I had just finished installing my webcam. I go downstairs for 3 or 4 minutes and I come back up. I see the screen is blacked out, because that is what my screen saver is. I move the mouse to close the screensaver, and I see this thin white line appear and slowly get brighter and brighter until I almost have to close my eyes. It's directly in the middle, and stretches from one side to the other, with approximately 10 pixels left on each side, of which is a less bright white line.
I have tried to bring the OSD menu up from the monitor and I can see the area where the menu usually comes up dim slightly. I have tried different outputs, so it is a monitor problem. I really hope that the monitor isn't screwed. Thanks in advance for those that are saying - DUH-ThisIs... and then nicely telling me.
Comment by jammer2552, posted on Nov 11, 2007
Is there a fix?
btw- goosed is to poke between the buttcheeks.
Comment by jammer2552, posted on Nov 15, 2007
About 2 days after I posted this, I went upstairs and moved my mouse, and the picture was actually back! I haven't turned it off since, I'm scared that it will mess up again. Btw - the screen image wasn't compressed - just replaced with pure white light.
Comment by jammer2552, posted on Jan 12, 2008
... It's back and it's not going away.......... :(
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 13, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am having a similar issue with my NEC multisync FP912SB monitor. In my case the problem is intermittent, the line remains at the same level of brightness, and the osd, when activated, is compressed in that horizontal line as well. The problem is occurring more and more frequently. Banging on the sides of the monitor sometimes brings the picture back temporarily. I came across this. http://en.allexperts.com/q/Monitor-Problems-2115/Thin-horizontal-line-monitor.htm
It states that the problem is called vertical collapse and is caused by the failure of a couple of I.C.s in the monitor.
Hope that helps.
Rating Locked! (?) jammer2552 has rated this solution as FixYa!
Solution #2
posted on Nov 10, 2007
Thanks for Trying (70)
shugster
Rank:Wiz Wiz
Rating: 79%, 79 votes
by the sounds of it the mon is in a word goosed
but please dont open it up to try and tinker with it !
as they hold a charge for a while beware !
Comment by shugster, posted on Nov 15, 2007
long may it last ! good luck
Rating Locked! (?) jammer2552 has rated this solution as Thanks for Trying
Can you Help with these Monitors problems?
Monitors
broken pins in monitor cable
I broke off a pin by accident... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
Monitors
Monitor driver
Dear Sirs! I'm very need the... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
