Question about Food Mixers
Disassembling the gearbox on Kenwood mixer A707
The motor and belt drive on this old mixer works fine, but the speed control doesn't get transferred properly through the gearbox. I disassembled the gearbox from the mixer, but cannot open it because one of the screws is under the belt wheel. I can see no way of removing the clutch mechanism or belt wheel.
Do you know how one is meant to do this?
(I imagine the mechanism is the same on newer machines. The clutch is engaged when the cover is put over the direct motor drive, when a pin pushes the 2 halves of the clutch together.)
  • Peter Nov 11, 2007
    As you can see, I need to remove the spindle with the conical piece on it, in order to remove the belt wheel which is loose on the spindle. This will enable me to remove the screw under the belt wheel, which is one of 5 holding the gearbox together.In use, the conical piece is pushed towards the belt wheel by a pin on the lid, engaging teeth on both parts. There is a spring between the conical piece and the wheel to hold them apart in the absence of the lid.
    See photos above.
  • 328 Answers
If the belt wheel is pressed onto a spindle, you need a gear puller. Do you have any pictures of this? I am trying to visualize the problem.
Posted on Nov 10, 2007
  • Lyle Siemens
    Lyle Siemens Nov 11, 2007
    I can see that it is pressed onto the spindle. Look for a roll pin going into the shaft. If there is non, removal will require a gear puller, a steering wheel hub puller may work too. Other than a gear puller, you could try to pry it up from the bottom but you risk breaking something. You can however use wood and tap it with a hammer. Just use a gear puller and that should work best. The conical hub may be held in place with a keyway in the shaft, but not always. Nice picture by the way. Hope it works, if you have more questions, please don't hesitate.
  • Lyle Siemens
    It also appears to be a coller below the cone, if thats the case, it is probably held on with a set screw which need a hex key to loosen. The cone itself looks like it needs a puller.
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
Kenwood acessories
Hello. your Kenwood Major is A707 ?
the new attachment for front and high speed outlet, not fit in A701/707 ..
Please visit our web site Kenwood Chef Restore in download section. you can download the compatibility of attachments
Regards
Jan 06, 2009 | Kenwood KM800 Major Classic Stand Mixer
My moter has gone can ifit a larger one
Hello.
not, you cant, because the screws of the motors 800 fit in different position.
the A701/07 models have 4 screws in the 4 corners. half body.
800w motors have 3 screws in the top .
Regards
Dec 19, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood Major Model number A707/A
Hello in ebay, you can get a gearbox for A701/A models ..
if you Kenwood is 1962 - 1975 is A701/A
looking the gearbox for this model. or in Billingtonelec.co.uk
Regards
Nov 11, 2008 | Kenwood KM800 Major Classic Stand Mixer
There was a smell of burning, i.e. very hot wiring insulatiuon (?) on old Kenwood Chef Model 901. Could it be the motor or some other component, and can I repair it? If it is due to overloading due to...
Hi sometimes, its not the motor, maybe its the speed control, in this model same A701 its centrifugal system, if the capacitor or resistor not working fine, give this smell . you must give your Kenwood for repair or check
kenwoodchefrestore.co.uk
Aug 16, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef A701 Variable speed controller malfunction. Appliance only operates on maximum speed.
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
Aug 07, 2008 | Kenwood KM300 Chef Stand Mixer
Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Jun 28, 2008 | Kenwood KM305 Stand Mixer
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
1,768 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
