Question about White Sewing 1418 Mechanical Sewing Machine
White sewing machine #1418 tension dial needs re assembled
I loaned to my friend my White sewing machine #1418 and she disassembled tension dial by accident. I need to re assemble. Anybody have schematics? or suggestions?
  • mitoppo Nov 12, 2007
    Thanks for your reply. Yes the main pin is still attached to the body. Here are photos of the tension parts.
  • mitoppo Nov 15, 2007
    I got it working again!
    Thanks a lot.
  • 106 Answers
SOURCE: Tension disc assembly - sewing machine
Sorry but there is no way to explain how to re-assemble the tension mech on here, you need to be actually shown or have someone do it for you. It is very fiddly and needs to be exact, can I suggest you get in touch with a sewing machine tech who(at cost) will sort you out.
Sorry I cannot be of any further help.
Posted on Mar 29, 2008
  • 26 Answers
SOURCE: thread tension dial on riccar sewing mach. needs repaired
Please, tell me, is the main spintle, still on the machine, or it came off with the rest of the parts?
If you can put the tension parts, the one next to the other in front of the machine, and upload a photo for me, it will be very easy to explain how to put them back.
Posted on May 30, 2008
  • 1952 Answers
SOURCE: sewing machine tension
The best that I can do for you is to tell the order in which the parts go back into place. You have three disks that are similar and a fourth disk with a bar coming out of it. Put the three disks closest to the machine and the fourth disk with the bar on it on the outside and the bar goes into the hole in the sewing machine. Before you push these parts onto the tension bar, you have to take the check spring (loopy spring thing) and sandwhich these four parts in between the loop of the check spring. As you are putting this into the machine, there is a sprocket type of assembly that engages the spring. Once this is in place, you have a cup shaped piece, then a beehive shaped spring, then a washer with a bar through the middle of it and a point (the point should go to the lower part of the bar). Then comes the silver wheel, then the number wheel is attached to that. I hope this helps you.
Should you need to purchase any parts for your machine, I do have them all available on
Posted on Jul 21, 2009
  • 255 Answers
SOURCE: sewing machine tension?
Hi! This might be a tension issue, but it also could be caused by the needle. For stretchy fabric you need to use a stretch needle or at the least, a ballpoint needle. (see my tip about which needle to use).
Let me know if this solves the problem, ok?
Happy Sewing!
Posted on Mar 05, 2010
Testimonial: "yes it was a combination of the two, thanks!"
  • 980 Answers
SOURCE: white 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
Posted on Apr 10, 2010
How do I replace the upper tension spring on White sewing machine model 1418?
Go on and you will see a video on replacing White tension springs. The videos are free and very good for lots of things..
Dec 31, 2017 | White Sewing Sewing Machines
Deagram of tension assembly for white sewing machine 1418
This is why you take the machine to a trained professional.
The only thing DIY about a sewing machine is what you can sew with it.
Jul 15, 2014 | White Sewing Sewing Machines
Does the bobbin on a white 1418 thread clockwise or counter-clockwise?
You can download a manual from here, just type in the model number and click on 'search' to locate your machine's one.
As a rule of thumb, the thread usually comes off a bobbin goes through the tension then reverses direction back the other way. So as you pull the thread, the bobbin usually turns anticlockwise. But always check the manual to be sure.
May 22, 2011 | White Sewing 1418 Mechanical Sewing...
Breaks thread after sewing about 8 feet. Thread is freyed away
try changing your tension (loosen) should be between 4-6 don't ever mess with the bobbin tension only the top, if that doesn't work change the needle, or re-threading.
Dec 18, 2010 | White Sewing 1418 Mechanical Sewing...
White 1418 sewing machine
Apr 10, 2010 | White Sewing 1418 Mechanical Sewing...
I need a manual for this machine- White 1418 sewing machine
go to and in the drop menu pick instruction manuals then in the model number put in w 1418 and it will bring up a free manual. I lost my manual and a friend suggested this and it worked good luck
Oct 30, 2009 | White Sewing 1418 Mechanical Sewing...
White Sewing 1418 Mechanical Sewing Machine Logo
406 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
