Question about Panasonic WJ-HD500BV/960
Panasonic DVR WJ-HD500B
When I turn the DVR on I get video to monitor but the front panel does not light up and unable to access setup to format, etc.....
Re: Panasonic DVR WJ-HD500B
The Web interface will not open says page is not there
Posted on Jul 06, 2010
0 characters
3 Points
I have a blue light and an orange but my tv will not come on
If you are referring to an R15 (the big box in the picture with your post), there should be 3 blue lights on the front of the DVR: one to the far left (power), a big circle in the middle, and one on the right indicating the resolution the DVR is currently trying to send to the TV. The orange light indicates that something is being recorded; either a show or something from DTV like channel listings. The orange light has nothing to do with your TV but may indicate that the DVR is downloading setup information.
As for turning your TV on, when you first get DTV, the DVR remote does not know how to talk to your TV set, only the DVR, so you have to teach the remote to talk to your TV. To do that, turn your TV on with the remote that came with it (or the on/off switch on the TV if you're a dinosaur like me) and change the TV input to whatever input the DVR is attached to - usually HDMI or Component. If you see something (a TV show, a guide, a DirecTV logo, etc.) you're in the right place. Now hit the Menu button on the DTV remote and you'll see a menu on the left that includes "Setup". Use the arrow buttons on the DTV remote to move to Setup, press Select, and then select Program Remote. Follow those instructions carefully, step by step, and you should be all set. (Caveat: I am working from memory so the exact wording might not match and I might have missed a menu level. If so, I apologize.)
May 27, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
Why dose my panasonic tv keep shuting off by it salf and then got wait a while for it to come on
This could be simple or a bit harder. First thing to check is your sleep settings on the setup menu. If those are not turning it off then I would check the power supply.
Feb 10, 2013 | Panasonic WJ-HD500 Hard Disc Video...
I have a Panasonic WJ-HD36 video recorder in my building
frist cheak ip address, gateway,subnetmask then cheak your network connection
Mar 12, 2012 | Panasonic WJ-HD316/6500 Series 16 Channel...
How can I reset my password to WJ-HD500?
The default is 12345 you should be able to go to setup and enter a new code
Feb 21, 2011 | Panasonic WJ-HD500 Hard Disc Video...
I have direct tv dvr my remote wont work,but remote works on my other recivers,has the ir gone bad and can it be fixed
It's possible that the IR receiver in the DVR has failed. It's unlikely to be the remote as it works with other devices. If the remote was working with the DVR before, then in most cases the problem can be corrected by resetting the DVR as follows:
Press the RED RESET BUTTON behind the access card panel on the front of the DVR. Wait for the program guide information to update then try the remote again.
Try this and post back if you need further assistance.
Dec 07, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
Dish DVR 625. Turned on this morning and it had corrupted hard drive. The unit formatted and reset itself. Now I have no access to the DVR feature. When I press record I get an Error 024 - "Unable to...
Hey there! Becki Barned with Dish Network customer service here!! I am sorry for your DVR issue! To get that resolved, if it has not been already, try to unplug the receiver from the power source for 10 seconds. If thsi does not work, a new receiver may be needed. Blog back if any other questions!!!!!
Aug 24, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I am trying to use a Panasonic Showstopper DVR
It records on one channel only, not a tuner itself...........
May 24, 2010 | Panasonic PV-HS2000 Showstopper 30-Hours...
How to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
Jan 08, 2010 | Panasonic WJ-HD316/6500 Series 16 Channel...
DVR is inaccessible. Error 024 "Unable to access this feature at this time. Data not available." SAT connection fine - just dvr issue.
You will need the receiver replaced as the hard drive is developing an internal error.Thanks for using Fix Ya.
May 01, 2009 | DISH Network DVR-625 DTV Receiver /...
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Panasonic WJ-HD500BV/960 Logo
420 people viewed this question
Top Panasonic TV Receivers & DVRs Experts
Are you a Panasonic TV Receiver and DVR Expert? Answer questions, earn points and help others
