Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
My vienna digital is stuck at fill water tank and ventilate
SOURCE:
mirran
  • 515 Answers
SOURCE: Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Posted on Aug 23, 2008
EsWorld
  • 1618 Answers
SOURCE: where is the flow meter in a saeco vienna machine?
The flowmeter is on the bottom of the machine follow the line that leads from the pump and you will see the flowmeter.
Posted on Jul 15, 2009
  • 1089 Answers
SOURCE: No water through brew group
Hi
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Posted on Nov 15, 2009
EsWorld
  • 1618 Answers
SOURCE: I've got a problem with my Saeco Vienna Digital.
Check the end of the steam wand it might be blocked, if it is not, then remove the steam wand and check the top there is a small teflon insert (this part is in some models) remove insert and toss. If that does not solve problem then machine needs to be descaled.
Posted on Jan 12, 2010
espressonist
  • 1711 Answers
SOURCE: CAN NOT MAKE A COFFEE DO NOT UNDERSRTAND THE MESSAGE I GET.
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Posted on Jul 17, 2010
Good luck
Apr 25, 2010 | Saeco Vienna De Luxe Espresso Machine
Stuck
Hi If you can get water flowing by opening the steam knob, then check the tip of the wand for a plug. Remove the black tip by loosening the cap then pull the black cover off. If a paper clip can go all the way up the wand that should be clear. If that didn't solve it, you have a blockage in your flow meter.
Jun 15, 2009 | Saeco Vienna De Luxe Espresso Machine
When i turn the machine on the screen says fill watertank. ventilate. the tank is full. i replaced the water level sensor. it still doesn't work. the magnet in the watertank is floating. any other ideas?
gnet goes in the slot. Flat side up. There is a cap that is rectangular in shape that holds the magnet from floating out. We use a tiny drop in the corner of the cap( I mean tiny) in place. That should correct your message.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Machine wont start
fill it with water start the machine when hot open side valve to let water out if it doesnt do the job remove water tank in the kit of the machine there a little pump put water in the pump in the water hole force water in there with side valve open let me no pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Ventilate will not disappear from the display,and the machine wont work
the procedure is filling water tank opening side valve that should clear the ventilate if is still there remove water tank apply water pressure with pump in the hole of water tank let me now pierre
My saco vienna superautomatica has been in storage. How do I get water to pass through the machine
fill up the water tank try it if nothing coming out in the starter kit they give a plastic pump if you have fill it up with water remove the water tank in the center hole were the water goes put the pump and force water in there if you dont have the pump try to inject water in there with at turkee pump anything you got it gonna prime the pump put water back open the valve for the water on the side where you do the milk should do it cheers
Jan 17, 2008 | Saeco Vienna SuperAutomatica Coffee...
Machine Is Stuck on "VENTILATE" Command
I had this "Ventilate" problem after descaling my Saeco Incanto de luxe. I tried all posted suggestions within my capability/user level to no avail. Just when I thought I was going to need to contact customer service for repair, I went through the menu settings and selected "yes" for Factory Settings and the ventilate message went away and the machine was immediately "Ready for Use". Weird, but it worked for me.
Dec 05, 2007 | Saeco Vienna De Luxe Espresso Machine
Fill watertank
float valve stuck. try unplugging and then empty tank.check to see that nothing is visable in water reserve. fill water tank to full and then plug unit back in. hope this solves your problem
Nov 16, 2007 | Saeco Vienna De Luxe Espresso Machine
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
218 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
