Question about Yamaha HTR-5560 Receiver
No sound from Center Speaker
Initially, the CS worked great on 'Small'. Then, after about a year, it quit working until I switched it to 'Non'. That worked for 2 years, and now it just doesn't work at all. Then I started having trouble with the volume knob and remote control. Today I had a brainstorm to unplug the unit (and re-plug it in) - yes, brilliance runs in the family. I also replaced the RC batteries, everything came back up perfectly. EXCEPT the center speaker. I've confirmed that the speaker actually works by hooking up to a currently working speaker connection. When I run the TEST mode, everything cycles thru except the center. Is there a fuse or reset on the HTR? Any suggestions? Thanks.
2 Suggested Answers
SOURCE: Yamaha RX-V1000 volume control erratic, remote
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver:
It's not much but I hope this helps.
Posted on Aug 21, 2011
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
I have a Yamaha RX-V2092 with a 7 speaker set up. Purchased new. Everything has worked great until recently. Now the center channel speaker, left front effect speaker & left main speaker short off...
It seems that the main sound processor comes into an error and so seems a fault on the board. Since checking for a component level solution is very tricky as the access is not friendly, what could be done initially is to remove and reset the boards, check for faulty connectors that seems to vibrate and bring in these faults. Check the solde joints of the connector pins on the board. Check and solder the processor IC and the allied circuits. If the fault seems to disappear when the set heats up then you must check using a magnifier.Check the solder on the audio driver outputs of the center, main , front and rear are clean.
If not refer and proceed with consensus as a false move can cripple the set.
Oct 28, 2011 | Yamaha RX-V2092
I have a Pioneer VSX-917V. After using it for a couple hours and everything working good, the center speaker quits working. I can reset the unit, re-ajust all speaker settings to my prefrence and the...
If new unit, don't waste your time, sounds like a faulty "Sound Card". possibly a slight hairline crack which only shows up when it warms up, yet after a few mins switched off, cools reconnects and so plays?
Dec 26, 2010 | Pioneer VSX-917V-K Receiver
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Center Speaker Audio Very Distorted
Love your screen name.
You didn't say what, if anything, preceded the appearance of the problem. There might be a clue.
Can you describe the distortion? Is it excessively bassy? If so, is it happening on all sources?
I'm assuming this is a modern digital receiver that is capable of many soundfield simulations as well as native Dolby Digital, DTS, multi-channel. If so we can use a stereo source and through simulation redirect some of it to the center speaker.
Using one of your receiver's many multi-channel simulation modes, put in a CD or tune an FM station and use it to diagnose the problem during later steps.
If it's only a single source and that source uses individual analog channel RCA cables, swap in another one or temporarily move the Center Channel feed to one of the other channels to see if it's before the receiver (in the source).or inside the receiver.
For multiple sources:
Is your Center speaker defined properly as Large or Small in the receiver's setup menu?The size refers mostly to the bass-handling capacities of all your speakers rather than their physical size. Speakers designated as 'Small' will not be sent much in the way of bass because they can't handle it well. The LFE/subwoofer channel(s) will get all the bass that was intended for them instead.
If you have a Small speaker improperly defined as Large it may be getting bass that it can't handle and that might sound like distortion. Having a Large speaker defiend as Small would result in less bass than expected but otherwise 'clean' sound.
Check the speaker setup in the menu for excessive volume level relative to the others. There is usually a calibration procedure the receiver will use to help you adjust the subjective voume of each speaker using white noise or tones.
Hope this helps.
Jan 18, 2009 | Sony STR-DE475 Receiver
Carver Sound Problems
your going to need this place to download the remedy's for your system
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Center channel quit woring
The center channel amplifier in the main unit isn't working. Check the warranty. If it's still in force Yamaha will fix it free. If out of warranty, they'll give you an estimate.
May 15, 2017 | Yamaha Audio Players & Recorders
Yamaha HTR-5560 Receiver Logo
288 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
