KitchenAid KFIS25XVBL Bottom Freezer French Door Refrigerator Logo
Water in freezer bottom
Would like evaporator hose cleanout instructions
In garage/works perfectly/slow leak coming from an insulated hose that goes directly into the bottom of the freezer itself.
The hose coming from the bottom of the freezer is draining the melted water produced during the automatic defrost cycle. Usually the water is collected in a pan somewhere around the hot compressor motor so the heat can evaporate the water.
The hot copper tube by the compressor is the high pressure tube going to the condenser. The other tube going to the compressor is the return line from the evaporator and, after normal operation, is cold to the touch. It is this cold refrigerant returning to the compressor that cools the motor.
Lg-LRFD25850 water dripping from bottom lt refridgerator door , refridge has water on that side
Probable drain hose issue.Hose is plugged up and it cannot get to the evaporator.Remove lower vent assy and see where the water is coming from.
Water accumulates beneath freezer basket and drips outonto kitchen floor. cannot get into area to cleanout welland see no type of removable tray.what can I do ? this is a whirlpool model # GX2FHDXVY04...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Water seepage at the bottom or floor of freezer. Water drips on the bottom floor of freezer, freezes, then ice build up.
You will want to check the rear of the fridge. There is an access panel there you can remove. Once removed, you can then check the drain hose and evaporator tray. There should be some water in the evap tray, if not, then the drain hose is plugged and causing water to run on floor.
2answers
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
2helpful
2answers
Water leak from bottom freezer door
If you remove the back cover off the unit, you will see the compressor with an evaporator tray, make sure the little drain hose isn't plugged and that there is water in the evap tray from drain hose.
1helpful
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
3helpful
Frozen water in bottom of freezer
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
5helpful
Lots of water in bottom of refrigerator
Every ten to twelve hours or more irregular intervals if equipped with an adaptive defrost control your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-25oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
