THE PENDILUM JUST SLOWS DOWN UNTIL IT STOPS AND THEN NEVER RINGS. wHAT CAN i TRY?
SOURCE: Car door bell won't stop ringing.
is there any type of check engine light on or any type of warning light is the sound of the bell the same bell sound when you open your door or seatbelt warning
SOURCE: security alarm ringing when in drive or reverse
try pushing down lightly on the parking brake and release it. you have pushed it down some and the parking brake is on
SOURCE: slowing down at around 40km/hr, the transmission jerks.
2008 Tucson? It should still be under warranty. Does it have more than 100,000 miles on it? Are you the original owner? If not, does it have less than 60,000 miles on it?.. If so, it's still under warranty - take it in to get fixed under warranty.
SOURCE: 2000 camry. blown head gasket (daughter drove car
Yes, you can, but not exactly recommended. If you are going to go that deep into it, then might as well do everything else. However, being unemployed tends to have a negative impact on the wallet....
I suspect it is more than just rings. I think that the walls have been scored badly as well. You may be able to use a borescope to take a peak into the cylinder through spark plug hole. Move the piston to bottom of stroke, and see what you can see. If scarred, much work will be needed. If hatches look alright, then you might be able to get away with just rings.
What kind of compression are you getting on #1 vs #2? This also might be a blown headgasket into an oil passage, or the head (perhaps block?) is ever so slightly warped in this area.
Testimonial: "Thanks for the quick response. Very much appreciated your input, all makes sense and got my mind on the right track again. Thanks"
SOURCE: dodge 1996 car
sounds like one of the courtesy light switches in the one of the doors is faulty
Testimonial: "thank you having it check out today let you no how it turn out "
