SC995 is a controller board not compatible error. You have replaced the controller board with the 2022 or 2032 board. All other boards and parts for this machines are the same. Only the controller board is different for all three models. But if you have not change the controller board and this SC995 appeared then the controller board is defective and need to be replaced.
Sorry not possible to be done. All other parts and boards are same on the both models. Even the RAM and the printer\scanner SD card is the same.NV ram is the same. But the controller boards are different for both machines. You will get SC995 if you put a mp4000sp controller board in mp5000sp. SC 995 is compatibility error for the controller board it self.
This error code can mean several things. However the most likely problem has do do with the finisher attached to the copier unit. The finisher may have been disconnected to the bridge unit or lost power. Check your connections to the finisher and make sure it latched to the main unit properly.
If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
SC995
Serial Number Setting Incorrect
The 11-digit serial number is printed on the data plate. This information is compared with the installed components to detect mismatches. Did you remove any of the machine parts or components? Reinstall anything you removed and see if the error is resolved. If it's a problem with the NVRam, you'll need to contact an expert.
Information Type 995 machine • Wrong After switching on the machine, was detected with the controller card mismatch CPM correct information sent by the Engine Controller.
Solution: Replace the controller card with the correct tab.
