Loud humming noise from subwoofer
When I turn the sub on it makes this loud humming like noise, all other speakers work fine, I opened the sub up and everything seems fine, nothing blown, any ideas? I have a Harmon Kardon HKTS14 subwoofer with the same problem, although I also sometimes get a screeching "fax" like sound from it as well. I am using the original cables to connect from the receiver (AS630), which are color coded purple. Should I try new cables, since these should be shielded? JE
  • 3 more comments
  • kip_morris2 Dec 06, 2008
    I have the same problem on a brand new PS-1200 speaker. (Yes, older model, but was never opened.) It makes this humming noise even if you disconnect the wires so I do not think shielding is the issue. Unless the power in the walls is causing this there is just nothing else it could be in terms of interference.
  • kip_morris2 Dec 07, 2008
    Wanted to add that I've tried various outlets in my home with the subwoofer always as far from the wall/potential interference as possible. It hums no matter what room it is in, upstairs or down. The only trick is that I have to "trip" it to "On" due to the Auto On feature, but then I can even disconnect the source so the speaker remains on with no wires whatsoever nearby except the power cord. The hum isn't loud enough to notice during the daytime use, but it will drive me nuts at night.
    Also, the power cord is two-prong, so please don't suggest it is a ground loop issue. Did I get a new sub with a bad transformer? Is this hum that common?
  • conanb Dec 15, 2008
    My sub has a similar problem, except the noise is very loud.
  • Al Jacobson
    Al Jacobson Dec 26, 2008
    I have a 15 year old Cerwin Vega sub -150 with 15" speaker. It's worked perfectly until last week. Now I get a loud hum even with no speakers connected. If I switch it from ON to Auto, the hum continues for about 15 seconds, then gets quieter. It only disappears completely if I pull the plug. Could it be a transformer? Are replacement parts available?
2 Suggested Answers
SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Posted on Jan 27, 2007
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
Subwoofer makes loud hum noise
4 possibilities:
1) ground loop or open connection on input.
2) close proximity to a CFL, or other flourescent fixture.
3) bad filter caps in the sub.
4) bad coax to the sub.
in any event, check wire routing. You can also track down the noise sources by using a portable AM radio tuned off station. it will pick all manner of RF noise around the house. Light dimmers are notorius noise makers.
Dec 20, 2011 | Audio Players & Recorders
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Apr 08, 2010 | Velodyne CT-100 Speaker
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Mar 28, 2010 | Velodyne HGS-10 Subwoofer
Subwoofer problem
Sound like a component inside the sub is overheating. Most likely will need to be replaced.
Jun 18, 2008 | Audio Players & Recorders
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Mar 09, 2008 | Audio Players & Recorders
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
1,313 people viewed this question
