Question about HP Compaq 1501 15" LCD Monitor
Compaq 1501 LCD Display
My 1501 display is showing a single constant yellow vertical line top to bottom right in the middle of my display. I presume this is a hardware fault and cannot be fixed ... any ideas ?
The display is out of warranty, so is there any chance I may be able to change a chip if you know where to look, or is it due for the skip ?
Cheers ... Martin ( Brighton, East Sussex, UK )
  • 63 Answers
Re: Compaq 1501 LCD Display
You are correct in that it is a problem with your LCD panel. Unfortunately, there are no chips to change, short of replacing the entire LCD. You can obtain a replacement screen from a vendor such as but they usually run upwards of $300 U.S. If that's a sum you're willing to pay, give them a look. You can replace the screen yourself, or send them the laptop and they will replace it.
Posted on Nov 12, 2007
0 characters
3 Points
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
A single line indicates a failure in one of the hundreds of connections on the back of the LED display panel. It normally cannot be repaired, but can be replaced. It may be more cost-effective to replace the unit.
Aug 26, 2013 | LG Flatron L1919S LCD Monitor
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
Corrupted display on LCD monitor.
Those lines on the right side show sign of damaged T-CON board, part of the LCD panel assembly, nothing you can do but getting the new LCD panel. The bright section on the screen looks like the backlight lamp reflector got out off the guide channel.
Sorry for bad news.
May 18, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Screen has multi color vertical lines, no discernable image...dead? Does same thing on muliple computers.
Vertical lines from top to bottom is the indication of bad LCD panel. It will get worst.
Jan 07, 2010 | Computer Monitors
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Display problem
What position of a single rose color line? Is it vertical line or horizontal line?
Jun 22, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
There is 2 strong and 1 light Vertical lines in the middle of the LCD displayed in my monitor
If the lines run from the top to the bottom of the screen and are perfectly straight then your panel is dying and not worth the effort to repair.
Having said that, you maybe lucky enough to find another monitor cheaply and just swap the panels.
Hope it helps =)
Jul 02, 2006 | HP Compaq 1501 15" LCD Monitor
HP Compaq 1501 15" LCD Monitor Logo
190 people viewed this question
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
