SOURCE: where is the oil filter on a 2007 dodge nitro v6
You can access the oil filter easily from underneath next to the front, driver-side wheel at the front of the engine. There is clear access to the filter there.
For more info on Dodge Nitro, visit the forum at
http://www.dodge-nitro.com/dodge-nitro/
SOURCE: I need a serpentine Belt diagram for a 2007 Dodge
This link should help you. Also you vehicle came from the factory with a diagram under the hood somewhere.
http://www.aa1car.com/library/serpentine_belt.htm
SOURCE: Can't remove rear wiper arm on my 2007 Dodge
Just Raise the arm up and rock it back and forth and it will come off if it does not come off on the first try use a little lubercating oil where the threaded shaft sticks out of the arm, contine wiggling till it comes loose. If you need more help let me know, this is the way to do it on most cars makes and modles.
SOURCE: need to replace fuse for cigarette lighter on 2007
if you look under your dash on the drivers side, you should find a little door or hatch. after you open it look on the back of the door for a diagram of the fuses...one should be labeled for the lighter, or accessory power outlet. use a pair of needle nose pliers to pull the bad fuse and push in the new one.
