Home | Projection Televisions | Hitachi 60V500A Cra...
Problem for Projection Televisions
Generic problem for all Projection Televisions
Hitachi 60V500A Cracked Screen Replacement
By jcmoran on Jul 04, 2009
One of my kids cracked the screen on my 60V500A, after much searching i found a replacement screen and ordered it. It's now arrived and i took the TV apart to replace it, now i have it back together and powered up the picture seems fine in the center but darker round the edges and slightly out of focus. Any ideas how to fix this? I've went through the service menu but nothing jumps out as the right setting.
Comments:
Jul 05, 2009
- How would I correct this, the inner screen came fixed to the outer? Is there a right way up?
Best Solution
posted on Jul 05, 2009
Helpful)
Skyassoc
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 255 votes
You have probably reversed the inner screen (Fresnel Lens) when you reassymbled the screen. It will give you the same effect.
Hope this helps,
Skyassy
Comments:
Jul 05, 2009
- First make sure the Screen assy is in the right direction. The Outer Screen(Lenticular Sheet) is ribbed and runs up and down and appears to have black lines coating the surface. It could be tricky to tell if the screen came with a Screen Protector. The Inner Screen (Fresnel) has a distinct circular cut appearance to it. If you have the old Screen still, look for the labels on the inside edge of Inner Screen. Verify location with the new Screen. If it is needed to flip flop the Inner Screen, the Screen assy is usually held together with a clear tape. Great caution should be had when taking this tape off to not damage any of the screens.
Hope this helps,
Skyassoc
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
Picture keep going off and on. Sound stays on picture goes to black for about a minute or two then... (More)
Answer
My daughter was messing with the remote and now it is broken. All of the buttons, except power, turn... (More)
Answer
Hi! the picture has dropped about 6 inches and the green control does not go up also the picture... (More)
Answer
No picture, but have audio. Replaced color wheel a few months ago, worked fine. Watching game... (More)
Answer
Seems like picture is on a skew. Another way to describe it is that it is in full view mode, but has... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
