Noisy dryer We just moved to a new house. Dryer is now noisy after the move. Is there something loose inside? We just bought this dryer a year ago. Checked inside and nothing seems to be damaged. Please help Our washer dryer has made a loud vibrating noise that comes from an encased part of the machine at the top in the rear right hand corner, this has only been the case since we moved. The dryer function works fine, just very loud. Any thoughts?
  • birdy1 Nov 10, 2007
    Not quite sure what the stone is but just took off the lid and there is a grey metal enclosed unit which had a cog which spins another cog and then into the machinery of the dryer. I put an electricians screwdriver on various bits with a bit of force and realised it was the screws holding down the second cog that were slightly loose. Ive tightened them up and it works fine. Is this the stone you mean?
    Many thanks for your help hope this helps others
    Problem Solver:
  • 10 Answers
I had same problem with washing machine. i found out it was the stone inside which holds it down while it spins. The screws or nuts or what ever is holding the stone could be loose.
Or it could be the nuts or screws of the actual drum that spins that got loose when you moved the machine
Posted on Nov 10, 2007
Hotpoint condenser dryer ctd 40g very noisy took black fan off and can hear something loose inside
something stuck in the blower housing? pull out off cabinet and u got a view
Nov 29, 2014 | Dryers
Whirlpool Duet Dryer Idler Pulley
see this causes and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our videos for other style dryers.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace the Belt along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This video walks thru another type.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor.
Oct 02, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer has started to be very loud.
Check ease of drum moving that it moved freely. Remove panels Is motor noisy? Check belt. Is movement of drum noisy? Make sure exhaust is not clogged. Can the air move freely to the outside. Make sure there are no kinks in exhaust line. Determine cause of noise then you have a few choices. Repair, lubricate replace parts or replace dryer. Sometime you just need to use it until it doesn't work anymore and then buy a new one depending on the cost of repairs vs. replacement.
Sep 30, 2010 | Fisher and Paykel Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Hotpoint CDT00G Very Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 16, 2009 | Hotpoint NBXR463EBWW Electric Dryer
GE Dryer DPSR483GA2WW too noisy
Remove the rear panel from the unit. This should expose the motor, drive belts, and the drum bearings. Now turn on the unit and your may be able to determine where the noise is coming from. Keep your hands away from moving parts and electrical connections!!
Ray
Dec 14, 2008 | LG DLE3777 Electric Dryer
Kenmore Dryer Drum is very loose and noisy.
It sounds like one of the rollers has a bad bearing. You will need to take the front off the dryer, unhook the belt, and remove the drum to check the rollers.
Nov 20, 2008 | AEG T57800 Electric Dryer
Noisy dryer
check to see if its level and let me know what kind of noise and age of drier
Nov 04, 2007 | LG DLE2532W Electric Dryer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
