SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: Can't start my Giant Vac leaf blower
Sounds like it may be a ground wire loose. Or the coil that you put on was bad as well.
Jim
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
SOURCE: when we started using toro
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
SOURCE: How to convert blower to vac. Toro 850 super
Remove the air inlet guard on the bottom by pressing the release and pulling down on the guard. It will tilt off. Remove the blower pipe from the front of the machine by pressing the tab and wiggling it off (It is usually a tighter fit than the air guard). Install the vacuum pipe on the air inlet, where the guard was removed. Install the bag where the air blower pipe was removed.
Best regards, --W/D--
