Question about Hitachi 50UX58B 50" Rear Projection Television
Picture jumps or shakes
I have a Hitachi 50UX58B V81023108, about 12 years old. The picture looks great but jumps or shakes. Any ideas what might be causing this. Does not do this all the time but starting to do this more and more.
  • an1412 Nov 15, 2007
    Thanks for the help. I will look for this.
  • monarchdr272 Aug 29, 2008
    50UX18B 1994 Projection TV has same problem - jumping or flickering picture. Sometimes when cold, somteimes when warmed up.
  • 375 Answers
Possible solder connection breaking down when the set is cold.look in and around the horizontal and vertical section for cold solder connections.
Posted on Nov 15, 2007
My 1993 50in. hitachi ultravision has no picture but still has sound. What can be the problem? A hitachi rep. told me to see if my dvd player shows a picture but I still don't have a picture.
If your unit is truly a 1993 model I'm amazed that it still turns on at all. Usually projection units quit after about 10 to 12 years and are worn out. Judging by the age of the unit the most likely problem area is the high voltage section. I have a tip at which explains how to troubleshoot this section and I have a tip at which explains how to remove and replace a circuit board if it becomes necessary to change out the deflection board.
Thanks for using FixYa and for the great rating.
Jun 08, 2011 | Hitachi 50UX58B 50" Rear Projection...
Hour glass picture sides coming in on hitachi rear projection 50ux58b
Its a convergence problem. You can get complete parts and instructiosn for this fix from They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Jan 02, 2010 | Hitachi 50UX58B 50" Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
Dec 23, 2009 | Hitachi 57F710 TV
Hitachi 43 inch
Have you cked 24volt neg and pos if not ok possible convergence ic and if you do change them make sure you ck the resistor by the ic's
Oct 18, 2008 | Hitachi 50UX58B 50" Rear Projection...
Jumpy picture
ck for dry solder joints if you take rear cover off and just lightly tap on convergence ic heat sink if the tv jumps then you have to remove the board and resolder the joints. also if you have a magnifying glass ck all solder joints on board when it is out
Oct 05, 2008 | Hitachi 50UX58B 50" Rear Projection...
Picture jumping
sounds like a capacitor and or the convergence IC's
for a tech to come out it's normally 300- 400
Dec 02, 2007 | Televison & Video
Converting Hitachi 50UX58B Ultravision TV to Support HDTV?
What is the digital television transition?
At midnight on February 17, 2009, all full-power television stations in the United States will stop broadcasting in analog and switch to 100% digital broadcasting. Digital broadcasting promises to provide a clearer picture and more programming options and will free up airwaves for use by emergency responders.
Nov 22, 2007 | Hitachi 50UX58B 50" Rear Projection...
Red color on screen is warped on my LCD projector TV.
Normally the oily fluid coming from a picture tube, is the coolant from the tube. It's very combustible and have been known to start a fire. You have two problems in this set. A leaking blue picture tube. A convergence circuit that needs repaired. Call a local servicer and see if they will give you an estimate over the phone. It's time to start looking for a new digital set. Good Luck.
Jun 23, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
209 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
