Phone had about 40% charge originally. Plugged into 2 different sockets. Won't charge? Phone is dead. Won't turn on or respond to any buttons pressed. What is wrong?
SOURCE: How to unlock ZTE merit with Net 10 and use att sim?
Good Morning Dear;
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: Unlock My NET10 ZTE Merit phone
Press emergency call in idle mode and input *983*987#, it will go to the factory reset interface and customer can reset the handset to Default.
Note:Please do remember to remind the customer this method will delete all the personal information in the phone.
Try to reset your phone once which will solve most of the issues on your device. Follow the below instructions to reset your phone:-
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe data/factory reset" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.
your phone speaker caused problem you can't hear with each other otherwise mobile sim card must be facced problem.
Have you turned on your data? If you haven't tried this yet you must in order to use web and emails. First, click on the bottom left button with the three lines. A list comes up find settings and press it, another list will come up. Next press wireless & networks, scroll to the bottom and press mobile networks. Once there press data enabled to turn on your data. That should enable you to access web and emails. Another tip, in the settings menu, press accounts & sync then press background data this will help with apps syncing. BE CAUTIOUS WITH THESE SETTINGS!!! I advise you turn them back off when you're done using them because they will use a ton of data if left on a may get you penalized by Straight Talk! THEY WON'T HESITATE TO CUT YOU OFF WITH NO REASON EXCEPT YOU'RE USING MORE DATA THAN EVERYONE ELSE IS!!! Sign out of email, Facebook and anything else that uses data constantly. I hope this is helpful good luck have fun!!!
