Question about NexxTech N600D DVD Player
Nexxtec N700 I keep getting a 'no disc' or 'disc error' message when trying to look at a DVD.  I tried a DVD disc cleaner, but  that didn't help.  Anyone else run into this or have any suggestions on what to do?
  • 64 Answers
Re: Nexxtec N700
Hi my father had the same problem and it turns out his dvd player wuld only play -dvds so check your dvds and see but sometimes a more expensive model will only play original dvds and not copies
good luck
Posted on Dec 18, 2008
0 characters
3 Points
Error message when put in dvd
You may need to clean up the lens with a canned air. If it does not solve the problem, possibly this drive is dying.
Mar 04, 2014 | GE DVD & Blu-Ray Players
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
Jul 17, 2011 | Philips DVP5982
Disc error message
Sounds like dirty laser pick up. Try a cd cleaner run through it to clean dust etc off. They can be purchased from any electronic sellers.
Jan 11, 2010 | Zenith DVD & Blu-Ray Players
Won't play dvd's
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens.
Aug 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG DVD & Blu-Ray Players
DVD Player N715-PD NX
It's quite possible the laser isn't moving properly in the player or it can't read the index on the DVD because the lens can't see it.
If it's still under warranty, it could be returned.
Sep 16, 2008 | NexxTech DP3222 DVD Player
Error 14
Check to see if you are using 16X media. If so contact Toshiba for a fireware upgrade. If that is not the problem try cleaning the disc and cleaning the unit with a DVD Laser Lens cleaner. Then try again.
Mar 30, 2008 | Toshiba DR4 DVD Recorder
"No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
Dvd played one day and hasn't since
the belt is broken for the carocel (the disc can not change) it is plobabely stuck b/tween discs therefore it keeps opening and closing saying error . eventually it turns off. can be fixed with a small elastic goody hair tie w/o metal clasp
Feb 11, 2007 | kawasaki SVP500 Multi-disc DVD Player
NexxTech N600D DVD Player Logo
194 people viewed this question
Top NexxTech DVD & Blu-Ray Players Experts
Tygh Duval
Tygh Duval
Are you a NexxTech DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
