It covers all under repair manual. I have visited this website 2-3 times for the repair of volvo v70 and vw manuals. They provide all kinds of manuals at a very cheap rates. Check it may be you will get something useful 1998 Volkswagen New Beetle Workshop Repair Service Manual PDF Download
left to right... 1. empty 2. e flashers 3.horn, brake lights 4.clock, trunk light, inside light, radio 5. rad. cooling fan relay (AC only) 6. right side running lights 7. left side running lights 8. right high beam and indicator 9. left high beam and indicator 10. right low beam 11. left low beam 12. reverse,turn signal and inst panel 13. main and transfer fuel pumps, auxiliary air reg., ox sensor heater 14. license plate and glove box light 15. wipers 16. rear defogger 17. heater blower (no AC) 18. cig lighter 19. rad cooling fan (no AC) 20. Heater blower (AC) 21. rad cooling fan (AC only) 22. empty 23. Ox sensor, idle stabilizer,seat belt warning relay, (Digifant only, control unit, idle boost control, idle boost valve) 24. inst panel lights, heater control lights 25. reading lamps 26. empty 27. empty 28. empty
Reversing polarity at the battery is a very bad thing and can cause a host of unpredictable problems. You are lucky that you didn't fry the alternator diodes (the battery is charging, I hope). Each of the problems you describe will have to be treated separately. 1. try replacing the turn signal fuse and flasher unit. 2. fuel gauge has a delicate resistor... probably the easiest fix is to replace the instrument cluster. 3. Heater blower fan has a resistor pack for different fan speeds, this may be replaceable, otherwise a new blower assembly may be the best way to fix it. Hope this helps
