SOURCE: Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
SOURCE: I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
SOURCE: subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: refrigerator and freezer not cooling sufficiently,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.”
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts.
It's on the outside of the refrigerator at the back near the bottom. If
it is humming or making a continuous noise and your refrigerator is
still not cooling, there may be a more serious problem with one or more
of several different components, we recommend contacting a qualified
appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Cooling is poor
For an overall understanding of how refrigerators should work, read
about refrigerators in the How Things Work section of our website. A
refrigerator or freezer that is cooling, but cooling poorly, may have a
problem in one of several areas:
Poor cooling is often the result of a heavy frost build-up on the
evaporator coils or a condenser that is clogged with dust, lint, and
dirt.
Evaporator coils
evaporator coils. You can't see these coils without removing a panel on
the inside of your freezer. A sure sign that there is a build-up is the
presence of any frost or ice build-up on the inside walls, floor, or
ceiling of the freezer. Such a frost build-up usually indicates a
problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in
every 24 hour period. If one of the components in the self-defrosting
system fails, the refrigerator continues to try to cool. Eventually,
though, so much frost builds up on the evaporator coils that the
circulating fan can't draw air over the coils. There may still be a
small amount of cooling because the coils are icy, but with no air flow
over the coils, cooling in the refrigerator compartment is quite
limited.
Here's an inexpensive, though inconvenient, way to determine if the
problem is with the self-defrosting system. Remove all of the perishable
food from the refrigerator and freezer, turn the thermostat in the
refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be
sure to have several towels ready in case the melting frost and ice
causes the drip pan to overflow). This allows the refrigerator to
defrost "manually." When the frost and ice build-up has completely
melted away, turn the thermostat back to a normal setting. If the
refrigerator then cools properly, it indicates a problem with one of
three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch)
The defrost heater
to check these components .... please refer to my solution in the below link....
http://www.fixya.com/support/t4189238-defroster_not_working_checked_defrost
If it still does not cool properly, there may be a problem with the
refrigerant level or the compressor. You may need to consult with a
qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan,
usually under the refrigerator, that need to be cleaned regularly. If
these coils get coated with dust, dirt or lint, the refrigerator may not
cool properly. The coils may appear to be a thin, black, wide
radiator-like device behind the lower kick-panel. To clean them,
disconnect the refrigerator from the power source, use a refrigerator
condenser brush (see the Appliance Accessories section) and your vacuum
cleaner to clean the coils of any lint, pet hair, etc. You may not be
able to get to all of the condenser from the front, it may be necessary
to clean the remainder of the condenser from the rear of the
refrigerator.
If I've been of Help to you... kindly take a moment to rate this solution.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Water Running in refrigerator from Freezer
heatman101
