Question about RCA RS2005 CD Shelf System
0 characters
1 Points
No sound from CD player. The turntable, radio & cassette work fine.
Can't get video to work so bose works with tv sound
Can't get video to work so bose works with tv sound I needed to reset the power on my bose and instead of unplugging the power cord, I unplugged the audio/video jacks because I couldn't see behind the
Oct 03, 2015 | GPX S7694 CD Shelf System
I have a rca rs2640 stereo system. The display, cd player, tape player, radio, and headphone jack all work. But when a cd, tape, or radio is playing, the speakers do not make any sounds. I know it is...
It sounds like maybe you have speaker wires touching somewhere. If they are touching it will blow fuses, especially if you turn the volume up to try to hear anything. DO NOT put bigger fuses in to replace the old ones, you will actually do more damage to your system because a higher volt fuse will allow a higher voltage to "spike" in your stereo and might just start frying internal parts.
Aug 10, 2009 | RCA RS2640 CD Shelf System
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
RCA RS2025 Bookshelf Stereo CD Player Hangs Up
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
Sep 03, 2008 | Audio Shelf Systems
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
Rca cd player
The loading mechanism is out of timing. This needs to be taken apart and reassembled. I'll try and locate the instructions for this tonight.
Mar 20, 2008 | RCA Lawton Turntable with Analog Radio/CD...
USB port won't playback
I have an RCA LYRA mp3 player and it works fine. I think this system has a very limited amount of mp3 players it will work with.
Dec 28, 2007 | RCA RS2664 Shelf System
Try a CD drive cleaner- this is a disc with a little brush and some cleaning fluid. Other than that it will be time for the next one - this is a no repair situation here I am afraid
Jul 06, 2007 | RCA RS2635 CD Shelf System
CD player will not read any disc
Try cleaning the lens, best way is to open it up and use rubbing alcohol (the purer, the better) with a q-tip. Wait for it to dry, then test it. If that doesn't work, you'll most likely need a new pickup. This might be of interest to you:
Apr 21, 2006 | RCA RS2652 Shelf System
RCA RS2005 CD Shelf System Logo
109 people viewed this question
Top RCA Audio Shelf Systems Experts
Jaime Hernandez
Are you a RCA Audio Shelf System Expert? Answer questions, earn points and help others
