Resetting the TI 73 calculator This should work for you =)
SOURCE: cracked TI-86 screen
well this isn't looking to good for you? The TI 86 isn't made anymore, so I doubt you can get it replaced. your luck has kinda run dry. You are probably going to have to buy a new calculator. Sorry to be the barer of bad news. Good luck though.
SOURCE: TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
SOURCE: TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
SOURCE: My calculator is stuck on garage collecting. How do i fix?
If it takes too long collecting garbage Press the [ON] button several times (3 to 4). If that does not stop it, removing the main batteries (NOT THE BACKUP) and leaving them out the calculator for a while will do the trick.
Hope it helps.
SOURCE: Upside down display
I have read that to invert the LCD-screen you just flip the polarisation-plate (the plastic film that sits over the LCD display) 180º, that is, upside down.
Did you or someone opened your calculator? He might have reassembled it wrong. Or was it a prank?
If that was not the case, your best change is to reset the calculator and see if it solves your problem.
To manually reset your graphing calculator:
This process should restore the graphing calculator to the factory settings.
Good Luck!
