u need to get a press down switch u need to look around the brake lever to see were will be the best place to put it then u and then if you don't have a brake light on back you will have to add it , you can get to ground from any were close and them the power wire caming from switch that you just put it in
hi i was just having a problem with the alpine IVA-D310 it was working fine and then i was just...
(More)
hi i was just having a problem with the alpine IVA-D310 it was working fine and then i was just fooling around with my settings and i dont no what i did but now after 3 seconds my screen goes blank and the little blue light on the bottom of the screen slowly flashes and when i tap the screen it turns back again and shuts off again if i dont touch it for about 3 seconds how can i fix this the screen stays on all the time like before? Even when it is just a cd in there it still goes blank until i tap the screen again
What Alpine cable connection is needed to connect my i pod touch so i can play the videos etc... its...
(More)
What Alpine cable connection is needed to connect my i pod touch so i can play the videos etc... its for a alpine iva-d310
