Are you accidentally doing 2 sided printing when printing envelopes ? That could be the reason it misfeeds. Check to see that 2 sided (duplex) printing is not chosen.
You will need to select the duplex option in the print options before you print. If you don't have the option you can manually do it but it will take a while to print out each page. You can also buy a duplex unit for the printer.
open the print preview by clicking on to the drop down arrow on the right hand side of the printer icon which you can find on any web page or email or a document that you are trying to print from on right hans side top. on the top of print preview window you would get different options .there is an optio which is for the font size/ by default it would be fit to page / change it to 75% or more according to your needs and click on the print option ans see what happens /
please let me know whether it worked or not /
i have other resolutions as well
thanks
Firstly in one PC reload the OS and other necessary softwares and try printing an email. If u get the same results, then check the printing options both on the printer side and the outlook print properties. Hopefully this wont be needed because when you reinstall the OS as a clean install it should print properly....sodeep
Your problem isn't in the printer. It's trying to print what you send to it. Check your settings in your e-mail program. You may be attempting to print all emails inadvertently.
Welcome to FixYa Mr. McMullen. Email options for characters per line is a parameter than you can customize. As you did not mention which email service you use I could not tell you the specific paths for mail options This may be a factor that would conflict with the printer margins limits which would cut the edge off rather than scale or format the print job.
Also on your email there is generally a print format checkbox but then again you would need to examine your email options.
Thanks for using FixYa and please repost if you need further assistance specifying your email service, Steve Medley
1) Within your application click on FILE and PRINT
2) Depending on the application in use, you may see either "Printer" or "Format for". Ensure your printer name is selected here instead of "Any Printer".
3) Click the up/down arrows next to COPIES and PAGES to see all the available setting options:
A) COPIES AND PAGES
Allows you to select how many copies you want and if you want to print all pages, selected pages or a specific page.
B) LAYOUT
Adjust the way the image is displayed on the media for multiple page printing.
C) SCHEDULER
Allows options for when to print a job, such as specific time or to hold the jobs, and the priority of the job to be printed for networked machines.
D) PAPER HANDLING
More page options, such as even or odd pages only, and reverse print order.
E)COLORSYNC
Connects to color options managed by the ColorSync Utility.
F) COVER PAGE
Provides the option of including a cover page or not with your prints.
G) PRINT SETTINGS
Select your MEDIA TYPE and INK. You can also create and save CUSTOM SETTINGS through this area.
H) COLOR MANAGEMENT
Adjusts BRIGHTNESS, CONTRAST, SATURATION, and INK balance. Also gives ability to allow COLORSYNC to control all printer colors.
I) EXTENSION SETTINGS
Provides the option for printing on thick paper and envelopes * This option may not be present with all models.
K) SUMMARY
Details settings chosen in other options.
After making the changes appropriate to your set up and print job, click on PRINT.
