Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Delonghi Dehumidifier DE400P / DH400P say...
By jgelman on Nov 10, 2007
Machine worked great for 1 season. Turned it on the next season and comes right up to E1. I am very technical and have had all the covers off, checked all the connections, cleaned some crud out of the tubes, cleaned a little corrosion out of the humidity sensor connector - but can't get this thing to work or the error to go away. Any Help would be greatly appreciated. Thanks, Jon
Same Problem
Jun 21, 2008
-   error code 2? -   Guest
Jun 20, 2008
-   Ok so I tried disconnecting the sensor from wire socket and when I turned it back on instead of getting error message E1 I now have Error message E2. My unit is less than a year old -   paall1
Jun 11, 2008
-   A few weeks ago the pump wasn't working so I pulled everything apart and found a small filter that didn't allow water to flow through it. When I removed the filter the unit worked fine. I didnn't notice any direction of flow note on the filter so I installed it reversed and it worked fine after that.
Now the unit goes to E1 right when you turn it on. I'll try your fix...Thanks!-   Guest
May 31, 2008
-   I have the DE500P but same issue with E1 message and units gets VERY loud.-   Guest
Solution #1
posted on Jun 09, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Solution #2
posted on Jun 24, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I believe the filter is actually a type of back flow valve. I pulled it off, cleaned it out with some bleach and water, put it back on in the same direction.
It works fine. Quiet with not errors
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
Humidifer is not taking out water. Is there a start capacator for the compressor?
Answer
wont work. water indicator light blinks red
Answer
Do you stock replacement 5Ltr tanks for an Amcor TC120 ?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
