Question about Thermador SC302T Electric Double Oven
Thermador SC302TS The lower door will not shut and the top door is starting to open a little when the oven is on, just enough to turn the oven light on. Do I need new hinges or can I adjust them? Thansk
4 Suggested Answers
  • 213 Answers
SOURCE: Thermador Oven SC302TS Owner Manual
go to this web site and you can request an owners manual
Posted on Nov 22, 2007
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 3463 Answers
SOURCE: oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
Posted on Dec 31, 2008
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from
Posted on Oct 13, 2009
0 characters
1 Points
SC302TS. Why won't oven heat?
If it's not the thermal fuse, it is often a control board failure. These boards are no longer available from the mfr but can be rebuilt at:
Often the relay boards need work too. We can rebuild these as well. Just contact us at FixYourBoard 512-355-1108
Aug 11, 2015 | Thermador Ovens
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
Thermador sc302tctop selfcleaning oven will not go on. Looks like
try holding the door in just abit when trying self clean
from the sounds of it you having issues with you hinges
it might no be able to grab the door and pull it in
there by cancelling the clean
Oct 09, 2009 | Thermador SC302T Electric Double Oven
Thermador oven door won't close all the way - seems like the seal is holding it open. I can press and hold it closed, but if I release, it pops out. The oven light stays on all the time. Model smw272
Have exactly the same situation. All the solutions I have seen talk about replacing the hinges or seal. But people report the same thing happens a month later. Looking hard at the door what it needs is something to pull it right at the top. So I installed a rare earth magnet from I used part number BX884DCS which costs $4. It mounts with a couple of screws and I put it on the door a couple of inches down from the top.
Its possible that heat from the oven will kill the magnet over time but for $4 I can replace it for a lot less than hinges and it works great. The door closes more securely than it ever did when the oven was new.
Hope this helps.
Aug 05, 2009 | Thermador SMW272 Electric Double Oven
Error F5 comes on when trying to bake
Ok, this is a control fault that may or may not be solved by initiating a hard reset. To initiate this reset, you will have to unplug the entire oven for 3 total Min's. it is vital that you allow three total Min's before you power up once more. if you cant reach the actual plug, you can shut of the appropriate circuit breaker as well for three total Min's. Once the hard reset has been initiated, power the oven up once more. If the same problem still exists, you will have to replace the Electronic Oven Control Board.
Please rate and god bless:)
Apr 03, 2009 | Thermador SC302T Electric Double Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
176 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Thermador Oven Expert? Answer questions, earn points and help others
