Question about Kenwood Excelon KDC-X789 CD Player
CD/Aux play i installed my deck into my car, i can listen to all the radio stations, even put them into the memory but for some strange reason i cant play the CD's or switch to AUX. Am i missing some component.
Re: CD/Aux play
For the "AUX input" source put it in standby mode and hold menu... scroll down to "aux in" and turn it on by pushing right
Posted on Feb 29, 2008
0 characters
3 Points
Every Button Switches Between Radio and CD
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Apr 18, 2014 | Panasonic CQ-DF203U CD Player
What are the two short female rca cables are that stick out of the back of my deck
Aux Audio Input. Lets say you wanted to hook up a DVD player and have it play through your radio, you could connect the audio portion of the DVD player to these inputs and put you radio on AUX and the DVD audio would play through your radio..
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 12, 2011 | Sony CDX-GT710 CD Player
Radio stations wont store once key is taken out
if the unit only looses radio station presets then there is a defect with the unit. if the unit looses all its memory, (clock, stations, settings) then there is an issues with your aux power. basically you have the main power connect properly so it turns on the unit while the cars is on but the aux power keeps those settings.
Mar 08, 2011 | Virtual Reality VRCD500-SDU CD Player
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio Receivers
Cant save stations to radio on a kdc-x7006u can play them but when switch power off they have to be relocated to be able to listen to the station we want
your memory constant wire the yellow one has to be hooked to direct power.there is a .5 amp inline fuse. otherwise once you shut off the stereo it will erase the memory...
Jun 12, 2009 | Kenwood KDC-X792 Car CD/ MP3 Player
Sub doesnt kick on when put cd in only comes on when turn on radi
I had the same problem, but in my case it was a factory amp.
The blue wire on the deck harness is for a power antenna, and only powers up when the tuner is in use, not in the cd or aux mode. Therefore if you are using the blue wire (on the adapter or car side) to power the remote power on your amp, you would need to connect that blue wire (on the adapter or car side) to a keyed power source. This way the keyed source supplies power when the key is on, and will not cut out when the mode is changed from "Tuner" to "CD" or "AUX".
I just connected to the keyed source on my radio harness, but then, I am not running any kind of system, just the basics.
Jun 03, 2009 | Sony CDX-GT210 CD Player
My kenwood stereo kdc-135 cr will not display the clock time.
Hold in the button that you change tracks or change radio station with
Feb 18, 2009 | Kenwood KDC-135 CD Player
Changed car battery & Kenwood execolon kdc-X592 AUX is gone
Try pressing 'menu', scroll to "built in aux", and toggle to the 'on' position. Then the aux input should be available again. The radio losing power would have reset any internal memory causing it to go back to factory defalts. Hope this helps
Dec 03, 2008 | Kenwood Excelon KDC-X592 Car CD/ MP3...
To listen to the aux input of the stereo you must press the source button. If you are listening to the radio it will go to CD when you press it if a cd is in the cd deck, if you keep pressing it you should get to the aux input.
Jun 11, 2008 | Pioneer DEH-P6800MP CD Player
No able to play mp3s on Car CD DECK
unfortunately the jvc radio model # kd-g140 will not play mp3 on a cd disk- it will play a mp3 player thru the aux jack on the front of the head unit- please rate my help
May 19, 2008 | JVC 50W x 4 MOSFET CD Deck with MP3...
Kenwood Excelon KDC-X789 CD Player Logo
335 people viewed this question
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
