Need to download VGA Controller,Ethernet Controller, Multimedia Audio Controller and SM Bus Controller for my DELL GX260 desktop with Philips 190CW monitor
find your motherboard model and go to dell and try downloading a driver
there. and if that doesn't work, then find your audio port and/or
chipset name and go to intel, punch it in, and look for the drivers.
should be a simple fix. let me know if you have any problems. cause
that fixed a problem i solved on my little brother's computer that is
the same model (case wise, but has my computer's type of motherboard, a
gx 270 so it thinks it's different) not having a "network device" it's
usually intel. if you can't find anything...go to downloads.com and
punch your audio hardware in. you should be able to find it out by
going to device manager: Start > Programs > Accessories >
System Tools > System Information > Components > Sound Device, Network, Display.
You will find your device names, installed or not.
Can you see what you are doing? let me ask you that before i post another comment. Cause if you can't see what you are doing I'd say to reinstall windows so you can see what you are doing or take it to a computer technician to atleast get the vga driver installed. Cause it's one thing if your network and Sound Device don't work but if you can't know what you are doing then that's a completely different issue ya know?
Use another computer to download the drivers since you cannot access the internet. Download them to a USB flash drive and plug it in the computer if you can do that (I say that cause I don't know if you can see what you are doing or if you can't access the machine at all) with your machine.
Akai digital photo frame ADPF07X I cannot change the calendar and time from the manual. Can alter...
(More)
Akai digital photo frame ADPF07X I cannot change the calendar and time from the manual. Can alter it using the menu but when I exit and check it, the details have reverted to the original set-up. First time using this, not enough details in manual. Would appreciate some help. Thank you, Kathy
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do...
(More)
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do anything either on the panel or in fs2004.
Loaded program and after it loaded plugged printer in and ''Found New Hardware'' window came up but...
(More)
Loaded program and after it loaded plugged printer in and ''Found New Hardware'' window came up but said it cannot find the hardware. The camera works on the printer but my computer cannot find the printer
