Question about Refrigerators
Bonjour wine cube #53372
Light comes on motor won't run
  • 1 more comment
  • ttrox Nov 10, 2007
  • Denden5136 Mar 25, 2009
    I have a bonjour wine cube and I cannot set the temperature. I set it and it and it reverts to 25 degrees C.
    Does anyone know how to fix this?
  • The Prisoner May 02, 2009
    I have the same problem. There is just no way to set the temperature lower than 77 degrees F.
    Problem Solver:
  • 11 Answers
The Bonjour Wine Cube Is NOT a refrigerator it has no freon it circulates air to keep wine stored at proper temperature for cellar. To chill place in fridge or get something with freon.
Posted on Oct 14, 2009
Need a manual for my bonjour tower wine cooler 1131044
Try Googling (bonjour)(1131044)(manual) without parens.
Dec 17, 2017 | Furniture
What is a cube wine rack?
Wine cubes are a versatile type of wine storage which considered being small and can fit large amounts of bottles. You should just stack bottles on top of each other allowing any type of bottle to be stored. This is convenient if many different types of bottles are being used.
Aug 13, 2012 | Furniture
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
I have a new Continental ice maker - bought 2 years ago, but was plugged in for first time yesterday. Motor won't run. Added water to proper level. Plugged in. Set cube size. In one minute red water...
Check the water pump, I had the same problem, the water pump was bad but unable to find replacement parts at this point. The pump is a ZB-1200 made by Zhongboa Motor Factory,
Good Luck
May 09, 2011 | Continental PortableCE-IM65151 Ice Maker...
The motor keeps kicking in and off - ir runs and then shuts off - then runs and shuts off - what is the problem?!
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 27, 2010 | BonJour 1131044 Wine Cooler
Wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Mar 01, 2010 | KitchenAid KUWS246E Stainless Steel Wine...
FRIDGE FAN DOES NOT COME ON
What is the cooling problem? Have you checked the fan after holding in the light / fan switch. Some fans go off when the door is open. Fan is probably stuck due to lack of lubrication. Check fan to see if it spins freely. UNPLUG UNIT BEFORE EXPOSING WIRES, be sure you are clear before plugging in while doing test runs etc.
Jun 27, 2009 | BonJour 53372 Wine Cube Refrigerator
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Unit not running (cooling)
feel the motor and see if warm. if so and not cooling then that is where problem is. more likely is the thermostat. (ignore earth wire to stat). this can be 2 or 3 wire usually. short together and see if compressor starts up. if so thermostat is at fault.
Apr 24, 2007 | U-Line 75WC Wine Cooler
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
