one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
there is a reservoir in the base of the dryer which holds some condensing water prior to the pump pumping it to the holding tank at the top this has a float swith to tell the pump to come on and drain water to top tank this is probably stuck in the on position so the machine thinks it is always full of water and its waiting for you to empty it,you need to remove side panel and remove flost switch to clean, remove condenser and put youre hand in back of unit if its still very wet in there thats the problem should be bone dry at end of cycle.
hope this helps
SOURCE: The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
