Seems like a main ground is out somewhere.
SOURCE: running lights for a ford f 550 will not come on
i spliced a wire from the tail light running light to the trailer light connection assem. where all the running lights were connected
SOURCE: headlight bulb replacement & side marker light bulb replacement
i think there are two flat guide pins that hold the headlight assembly in .. just pull them straight up ..and the assembly should come out ..hencse replace the bulbs.
SOURCE: How to change front spark plugs 86 ford econoline
try coming up from the wheel way, on your plugs. the rest sounds alot like cat converter.
hope 2 help shack
SOURCE: how do you replace the front side marker lightbulb
Remove headlight you will see 1 ( see pic) rods on top of the headlight you are going to turn them then pull up on the rods the pull out on the headlight.The look at the back side of the marker light and you will see a tab on left side push it the lenses will come out.
SOURCE: how to change front driver side 2004 g35 coupe marker light
Just pop out the side marker from where the marker meets the fender well and push outward on the side marker. It has a metal clip retaining it to the bumper.
This entry was in January, most likely you figured it out already.
