Question about SAMTRON 55V 15" CRT Monitor
I need samsung samtron 55v vga cable input & output connection with pin no. & Colour code diagram
I have colour issue with my Samsung CRT 55V monitor. The main colour look green and also the Red and blue works It seems to be an issue with the RGB cables soldered to the wrong pins. Please guide..
I think this problem might be VGA cable or colour IC of the monitor,so please if you can change these two things ,so very well, other wise you will go to the service center.
JAIN_IT {INDIA}
Sep 26, 2010 | SAMTRON 55V 15" CRT Monitor
I want to know colour code of wires for 15pin vga socket of 55v samtron monitor
You will find the detail mapping of the Colour Pins in the Samtron 55v Monitor in the below link:
http://www.scribd.com/doc/6967245/AN15VS-Samtron-56V56E-Samsung-551VS
Hope this helps.
Jul 05, 2010 | Computers & Internet
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Vga
psl show me colour codes of monitor vga cable
Apr 13, 2009 | SAMTRON 55V 15" CRT Monitor
Vga Port
hey there!
by default, you cannot connect a tv signal cable like that..mainly because, the monitor does not have a built in tuner :)
what you need to do is get yourself a tv tuner card, internal or external and you're good to go :) you would need your entire PC though..some external tuners allow you to connect without the PC itself :)
Jun 03, 2008 | SAMTRON 55V 15" CRT Monitor
Problem with the vga cable
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Mar 31, 2008 | SAMTRON 55V 15" CRT Monitor
Replacing vga cable
A VGA cable is a D-Sub 15 pin cable.
Connector information:
http://en.wikipedia.org/wiki/VGA_connector
Pinning information about midway down the page:
http://myhometheater.homestead.com/vgacable.html
Is that what you were looking for?
Mar 27, 2008 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
69 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
