Question about Frigidaire ATF6000ES Front Load Washer
Frigidare affinity front load washer
I have a puse error that i cannot clear. i have unpllugeed the machine to reset it but that does not work. what do you suggest? what does this code mean?
  • 3 more comments
  • Anonymous Nov 10, 2007
    I also have a PAU error on my washer. It doesn't matter what button I push it won't clear it. It just reports that there is and Error. I have unplugged it and left it for awhile, re-plugged it and nothing has changed.
  • mike187fs Dec 02, 2007
    exact same problem.  PAU error and washed will not start.
  • Anonymous Dec 10, 2007
    I have a puse error that i cannot clear. i have unpllugeed the machine to reset it but that does not work. what do you suggest? what does this code mean, and how do i clear it?
  • mcjazzycat Jan 16, 2008
    We have had the absolute worst experience with this washer. It beeps
    any time, turns on and off ALL the time, and we never know if and/or
    when the washer will actually come on and wash the clothes. I've had to
    smell the clothes in the morning to see if it actually turned on over
    night and washed the clothes.
    We have had it replaced once under
    the warranty and will have to go back to the dealer before the warranty
    ends to try and get a new/different model washer - one the WORKS.
    Has anyone else ever had this problem?
  • Anonymous Jun 03, 2008
    E21 error occurred while doing a spin cycle. I have tried to reset the control board by unplugging and letting the unit sit. The lightsare on, 12 minutes still reside on the timer.Water still sits on the bottom of the bin.
    This machine is 2 years old.
  • 156 Answers
Is thse the digital panel if so the control board needs replaced
Posted on Feb 27, 2008
I just washed clothes and the washer now will not light up turn on there is no sign of power i unplugged it to see if it needed to be reset nothing help!!!!!
Posted on Jun 02, 2008
How to reset frigidare affinity front load washer
try unplugging it for 5 minutes sometimes it resets the board
Aug 25, 2014 | Frigidaire Washing Machines
E45 error on frigidare affinity washer
Hello efrendepaz - That is correct, typically error code E45 indicates that the washer has detected a Main Control Board issue. The control board will need replacing and regrettably this is not simple DIY job. I would strongly recommend connecting with a professional to move forward accurately.
Mar 13, 2013 | Frigidaire Affinity ATF7000E Front Load...
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a frigidare affinity front load washer the drum seems very loose is this normal?
yes as it it is spring loaded ,thier is only one bearing at the back but the support mounts are all spring loaded ,you could get someone to take the top off and make sure that the springs are all connected and one of the support brackets on the drum isnt broke off
Dec 06, 2011 | Frigidaire Affinity ATF7000E Front Load...
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
304 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
