If you are able to open the Start menu, you can type "recovery" in the search field and try to run the Acer Recovery Management software. If you are not able to run any app AND you have made an USB Recovery disk, you can restore the OS by booting from this USB disk - plug it to the USB socket, restart the computer, tap the F12 key on a BIOS screen, then select the USB disk to boot from. After booting from an USB drive, you can select what type of restoration you need (quick or complete).
If you have not made an USB Recovery drive, it is only one method available: reinstalling the OS from an external CD/DVD disc.
SOURCE: acer aspire 5730z - Keyboard problem
no it will not happen ........but i think once u check it with ur dealer.if it is a brand new u will have warranty....so check it......if there is some problem after checking i can help u....u r requested to cantact me after the check........because this is the ist time i am hearing about this problem
SOURCE: restore factory settings to acer aspire laptop
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at http://www.vtechsquad.com/acer-support/
Try F-8 at boot. Safe mode with networking
