Back to:
Tags:
Sony KDF-E50A10 50 in. HDTV LCD Television
KDF-E50A10 Sony TV Purchased May 06 (by 5 users)
posted by eing on Nov 10, 2007
Horizontal line of 28 boxes 3/8 inch on a side, 6.5 inches from the bottom of the screen. Close examination of boxes show a matrix of vertical bars, 6 columns and three rows. Bars vary in color and seem to change slightly in intensity and color with scene being displayed. Other then distracting line of boxes, images is HD quality. Problem first appeared 2nd week of Nov 07.
Ron Mc
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by paulandga, posted on Jun 30, 2008
Same issue - 28 blocks horizontal across screen starting as a single line. Now 4 of them 1 week later.
Sony no help.
Any suggestions
paulandga@comcast.net
Comment by fred2222, posted on Apr 30, 2008
Same TV, Same problem on top 1/3 of screen. No one seems to know and finding out that Sony sucks. TV is 3 yrs old. Got Charter Cable with DVR. Bypassed everything, no differance. Antenna or componant, makes no differance. DVD does it too. Someone told me its a B block at $1100. I find that hard to believe. Any other ideas anyone ? dasnj@sbcglobal.net
Comment by yanda, posted on Mar 21, 2008
Panasonic 32 inch LCD. started with squares, 1/2 inch on the top of the screen then a second row appeared this time it was long rectangles, about 2 inches long, now a third row has appeared covering more than half the screen from top down. This only happens when the cable box connection is selected. Bars are there even if cable is disconnected. Works fine with DVD or plain TV.
Tried turning off, unplugging etc.
Comment by Guest, posted on Dec 16, 2007
OUR TV WAS PURCHASED MARCH OF 2006, WE ARE HAVING THE SAME PROBLEM. HORIZONTAL RECTANGLES WITH VARYING DEGRESS OF COLOR CHANGING CONSTANTLY.
Best Solution
posted on Nov 10, 2007
Helpful (85)
guss12
Rank:Apprentice Apprentice
Rating: 90%, 1 votes
IF THIS HAPPENS ONLY WHEN USING HD SORCE THEIR IS A MODIFICATION TO BE CARRIED OUT.IF NOT THE OPTICAL BLOCK WILL REQUIRE REPLACING.
Rating Locked! (?) eing has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on KDF-E50A10 Sony TV Purchased May 06:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
How do I turn off the subtitles?
I have had my tv for approximately 3 years. I have already...
We have purple and green strip / shadow around al the...
Could this be opticle block or light engine problem? Very...
No picture or sound. I replaced the XL2400 lamp and no...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
