Question about JVC KD-G200 CD Player
Volume control volune seems to be stuck on 15. can't get it to go up or down.
  • 4 Answers
Re: volume control
Have heaps of manuals. Do a search.
Posted on Jan 22, 2008
0 characters
3 Points
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio Receivers
My volume is stuck on loud and won't turn down on my dual xdmr 7700 car stereo
Either your volume control is not tracking properly or the audio chip responsible for volume change is not working.
Sep 20, 2015 | Dual Car Audio Receivers
My Bluetooth keeps coming on at volume 21 I have to turn it down to 5 every time I get a call then it goes back to volume 21 how can I keep the volume at the same as number 5 seems to be the best volu
It seems you have a DEFAULT position and with that said, your device will always reset to the 21 volume setting. Contact the manufactures customer service personnel to go through the process of re-adjusting the controls.
Dec 01, 2014 | Car Audio Receivers
Volume decreases drasticly after playing loud 15-20minutes
Shes overheating and thus goes into emergency mode and shuts down the volume to help cool down the built in amp . Dont know if it has a built in fan (likely not) but its overheating which can be a number of reasons why...from a failed heatsink componet, inadequet venting, shorted circuit. Can you take it out and inspect it?
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
When I adjust the volume, I'll turn the knob, for instance, counter clockwise to turn it down. It will go down a couple digits and then may go up again.
hi richard, seems as if your rotary volume control internal switch pins are wearing out. this is a typical problem on many units that use rotary/digital encoder volume controls. before replacing the control clean the face pins, or have the pc board checked for moisture damage, or have the solder joints checked on the volume control. cheers.
Jun 23, 2012 | Kenwood KDC-322 CD Player
Rear Speakers
Hello kaykayscott1,
Here's a link to the manual.
First make sure that the green green/black and purple purple/black pairs of wires are properly connected to operate the rear speakers.
You can check and adjust the "fader" and "rear volume" settings from the front panel. Go into settings by pressing the CONTROL knob. Then press CONTROL repeatedly until you get to the setting you want to check or adjust. When the display reads "R-VOLUME", turn the CONTROL knob from 0-35. Press CONTROL repeatedly again until the display reads "FADER" and turn the CONTROL knob from Rear 15 - Front 15 until you get the setting you want. Exit audio control by pressing any button.
Hope this helps.
Jul 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Mar 17, 2008 | Phase Linear 160W AM/FM/CD Receiver W/...
Volume of my stereo went to maximum.
Before you do damage the speakers, locate & remove the fuse/s for the radio. This will at least disable the unit until the problem can be isolated.
Does the 530's owners manual have any info regarding resetting the radio? The unit maybe stuck in a loop or is processing an error & won't respond to external commands. Today's in-dash units are microprocessor controlled & occasionally need to be rebooted, like a windows based PC. Removing the the fuse/s may accomplish this. Wait for about an hour, re-insert the fuse/s & see if the problem is resolved.
If not, have you checked with BMW? There may be a service bulletin covering the wiring in the steering column that might be at fault. Good luck.
Feb 27, 2008 | Car Audio Receivers
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
JVC KD-G200 CD Player Logo
200 people viewed this question
Top JVC Car Audio Receivers Experts
xxxxxx xxx
Are you a JVC Car Audio Receiver Expert? Answer questions, earn points and help others
