Question about Car Audio & Video
Popping noise in new stereo install
I just installed a new stereo and speakers in a 1966 mustang. when I turn on the stereo I hear a popping noise through the speakers any Ideas? How important is the + and - connections on the speakers and could this cause the problem?
  • 46 Answers
Does this only happen when you turn the stereo on? If so, it's perfectly normal. It happens when the amplifier in your stereo powers up. It's an older car with "unshielded" wiring that isn't going to be grounded properly. Oh, and to answer your question, yes, the plus (+) and minus (-) are for positive (+) and negative (-) terminals. Make sure that red is on positive and black is on negative. Reversing the polarity (installing the wires backwards) normally won't make the system stop working but it can damage your new speakers.
You also should make sure that you've connected the stereo ground. It will probably be screwed onto the back of the stereo and if there isn't a provided green wire in the bundle coming from the car than you'll just need to find a place to attach it to the car's metal chassis.
Posted on Nov 10, 2007
Why would only 5 of 6 speakers work after new head unit car audio install?
Either that speaker is not connected or, the speaker is blown. To test: Disconnect that speaker from the stereo and, using a 9volt battery, tap the speaker's + and - to the battery's + and -. You should hear a "pop". That would indicate that the speaker works. DO NOT connect the 9 volt battery to the stereo side of the speaker wire!!!! 3_24_2016_7_22_43_pm.png
Mar 10, 2015 | Car Audio & Video
1966 ford pickup 352 motor turns over but acts as if the battery is dieing has new starter battery, cylanoid and wires
Battery may not have enough cranking amps to turn it over. Those old fords need at least 800 cca and to be fully charged. Keep in mind that not all new starters (parts in general) are always good. Make sure nothing else is drawing a bunch of juice from the battery at the same time. Like an aftermarket stereo for instance.
Nov 12, 2012 | 1966 Ford Mustang
My stereo in my mustang was stolen and all the wires were cut i need to know what wires do what so i can install an aftermarket cd player
Okay it is very simple but if you don't know what your doing you should google this info "1999 ford mustang stereo wiring diagram" and something should pop up and you can usually print it out or download usually I print them out.
Good Luck!
Feb 07, 2010 | 1990 Ford Mustang
How to install accelerator pedal spring in 1966 mustang.. how does the spring install
i have a 66 mustang. thespring attaches to the throttle body and not sure from there
Nov 06, 2009 | 1966 Ford Mustang
1966 mustang coupe motor 289,4 barrel carb.automatic trans. makes a noise when put in reverse,is this normal?
What kind of noise? A clunk, chatter, whir, grinding, or what? If it's a clunk, you may have a worn U-joint. Test by holding brake on and change between drive and reverse and back. If you hear a "clunk" when the tranny engages, it's probably a worn U-joint. Not a hard repair to do in the driveway. Always change BOTH front and rear U-joints - if one's worn, so's the other.
Oct 28, 2009 | 1966 Ford Mustang
How do you install lap belts on a 1966 ford mustang?The floorboard was replaced and there are no anchors on the new one.
I would search online or call older Mustang parts suppliers to find mounting hardware.
Here's an example of one retailer that might have what you need or point you in the right direction...
tech support email
phone #909-364-1372
Oct 23, 2009 | 1966 Ford Mustang
Need factory stereo color codes
best way is to get in the with a multireader and find a constant power and a ignition, for the speakers, i use a AA battery with a wire on each end, to test the spekers, you will hear a pop from speaker, so you can find which wires go to what speaker.
May 05, 2009 | Car Audio & Video
1969 ford mustang mach 1 brake / stop light switch challenge
Most tail light problems are a result of a bad ground......somewhere.
Sep 16, 2008 | 1966 Ford Mustang
1966 mustang motor mount installation
Can you supply digital photos of what you have?
Charlie Kuss
Jun 21, 2008 | 1966 Ford Mustang
Speaker Pop when i turn on or change tune on radio
the speaker is probably worn is it factory is the speaker wires crossed need more detail
Mar 09, 2008 | Sony CDX-GT710 CD Player
Car Audio & Video Logo
612 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
