Question about Toshiba TN50V71 50" Rear Projection Television
Toshiba TN50V71 Have blue ghosting on screen. Double image. Mostly on text or white objects. Any info on what part might be out. Thanks!
  • Anonymous Jan 13, 2008
    kuyp
    President:
  • 4,402 Answers
Http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Composite output has ghosting around the video (sort of an auro around all images on screen, including text and video). dvd menu also has this problem, so i verified that it is the output of the recorder...
Try reducing your sharpness value on either your TV or the player if applicable. Also disable any edge enhancement or "DVE" modes on the TV if applicable.
The easiest way to adjust sharpness control by the naked eye is with a calibration disc. Alternatively however, just for sharpness if you have a screen full of text and/or lines do the following;
Reduce your color/saturation value all the way down...this will make the picture black and white.
Then reduce your sharpness control until the "ghosting" effect or any additional white lines on text edges and line edges disappear.
Then you can return your color/saturation value back to normal.
Hope this helps!
Jan 12, 2011 | Toshiba DR4 DVD Recorder
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
50inch toshiba color problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 03, 2009 | Toshiba 50A62 50" Rear Projection...
Blue ghost
I have blue ghosts/shadowing at the top of the screen.
Sep 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Hitachi tv, model 53udx10b
Sounds like you need to run Magic Focus.
Sep 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba TN50V71 50" Rear Projection Television Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
