Home | Vizio | GV47LF Television | Same
Vizio GV47LF Television
Problem for Vizio GV47LF Television
Same
By blair183 on Jul 04, 2009
we thinking lighting blew a fuse...Can u explain where the fuse is?
Solution #1
posted on Aug 25, 2009
Not Rated)
pjnewman508
Rank: Apprentice
Rating: 0%, 0 votes
Our Vizio GV47L would not power up (the "Vizio" emblem on the front of the set was black also). I got scared reading the one solution here which talked about a soldered fuse, so I called in the repair folks (they offered a free estimate on site). Initially, the repairman said he would have to take the set off-site, and we were looking at hundreds of dollars for the estimate and resolution. I pushed the fuse issue. He agreed to open the set for free, but if it was a fuse the charge would be $75. I agreed. He layed the set screen down on a padded table (you will need to do this to unscrew the speakers). There are lots of screws, and typically the ones in the middle of a line of screws are different sizes. Sure enough, when he opened the panel I could see that there was only one regular fuse on the whole tv. It is on the Power Board circuit panel. If you are looking forward from the back of the unit it is near the top left position. The fuse is not soldered. He popped it out and sure enough it was blown. He installed a new fuse and the tv works just fine again. It was a cheap fix at $75, but I'm reasonably handy and could have repaced the fuse myself for a couple of bucks. Oh well, live and learn. I hope this helps somebody!
Was this helpful?
Yes
No
Popular Solutions for Vizio GV47LF Television
Questions and Unsolved Problems for Vizio GV47LF Television
Do you recommend Vizio GV47LF Television?
Answer
Answer
picture went blank, now TV won't respond to any command and screen is black. I unplugged then... (More)
Answer
slight buzzing from back right of set Picture brightness flickers and is somewhat dimmer apparently... (More)
Answer
My vizio gv47l went off the other night and now will not power up . i unplugged it and plugged it... (More)
Answer
My Vizio Remote Stopped working on MyGV47L television. I tried reprogramming it with the codes in... (More)
Answer
What part was it that dpdixon's repair person replaced?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vizio GV47LF Television:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
