Question about PC Desktops
Pc audio after formatting hard drive on pc i have found that i no longer have any audio capabilities,but everything else still works as normal,
  • 93 Answers
Re: pc audio
You need a driver for the sound card
do you know the make/model of the card?
if you want you can remove the card and get the details from it
i will get you the driver or if its on board sound then i need to motherboard number
just give me either details Im waiting to help you !
Posted on Nov 10, 2007
  • 46 Answers
Re: pc audio
There are some questions that still need to be answered. Is the hard drive your primary volume (C:\ drive)? Is your sound a seperate component (like a PCI card) or built onto the motherboard (onboard)?
The short answer is that you'll need to manually add the drivers for the sound. Your operating system is normally able to detect plug & play (PnP) devices but not always. If you're running Windows open up your Control Panel (Start > Control Panel) and then double-click on the System icon. Next open the Hardware tab and click on the Device Manager button. Look for any unknown devices. The will have a yellow question mark next to them. If there's only one, chances are good that it's your sound card. Double-click on it to bring up the properties and click on the "Update Driver" button. You can try to let Windows automatically search for the best driver, but it's probably already done that and failed. So, you just need to tell Windows that you want to manually choose and install it yourself. Choose "Sound, Video & Game Controllers" and then when the available list comes up click on "Have Disk" and point to where you have the driver.
Hope that helps.
0 characters
3 Points
Formatt win7 to install winxp
when you boot from xp installation cd it should start but if as you say nothing is happening there may be a problem with the cd or the drive. If you're sure it works properly you can always install your existing hard drive (the one with win 7) in another computer and format it then replace it and try again. When you format it you will wipe everything and it will be blank.
Aug 02, 2012 | PC Desktops
Safe Mode is active because Windows no longer is capable of working otherwise - it's corrupted. Use the Safe Mode for what it is designed to do - to allow you to backup your files - then perform a full reinstall: use the normal format option when asked during the process.
Dec 07, 2010 | PC Desktops
I have a number of RiDiscs with 4.7GB of material ( lectures) that I want to download on smaller discs so that I can play on my car cd player. How do I accomplish this?
The easiest way:
check the item on the link below:
Copy your audio file from the disc to a USB (pen drive) I am assuming your files are in mp3 format. Else use the audio ripping software mentioned below to rip the audio file and save in mp3 format and copy that file into the pen drive/SD card.
Connect the transmitter to your cigarette lighter adapter. Turn your car radio on. Tune the FM channel to a frequency, where there is no radio channels. Note that frequency. There will be a + and minus button on the transmitter. Press it up or down to bring the transmitter to the noted frequency. You can now hear the audio through your radio.
Different options of this transmitter are available. Some use a SD card instead of USB drive. All cost around $25.00
The second method is to rip the audio files to your hard disc. Use any software. For an example,
Check the link below:
Download and Install. If your cd player is capable of playing MP3 files, rip the audio files from your disc as mp3 files to your hard disk. copy them to regular cd's. (assuming you have a CD burning software)
If your cd player is not capable of playing mp3 files, rip them and save as .wav files.
Then you need a cd burning software.
Go to the link below:
Download K3B. Install
Open it. Select, a new audio project.
Drag your .wav files into it. Burn it. and you are ready to go.
Feb 25, 2010 | Compaq Presario 5000 PC Desktop
I can not load an OS,and the hard drive shows 0 space free. How can I fix this. ML6732 Laptop
Either format the hard drive (and lose everything on it) or the drive may have failed and you need a new one
If you found this useful , please rate below
Kind Regards
Jul 02, 2009 | Gateway PC Desktops
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
How can i format my hp desktop??
Well there are a couple different solutions. If you have another hard drive replace it with your other one and make the one that you want to format the secondary hard drive. Then after you boot the computer, all you gotta do is go to my computer and which ever drive the hard drive is set up on you can right click on the right drive. Go to where it says format and click on it and then follow the instructions.
You can also format the hard drive if you got a windows disk. Just put the disk in your cd-rom and restart the computer and then go through the setup process. You will get to a point where it will ask you if you wanna keep the files the same or do you wanna format the hard drive. There are two options for fomatting: There is a quick format or a full format. If you wanna totally wipe everything off the hard drive make sure you do the full format. It only takes a little while longer than the quick format process, so you are just better wiping it totally clean and then reboot windows on the hard drive when it is done formatting......
Jul 27, 2008 | PC Desktops
can u expalin your problem
Jul 09, 2008 | Compaq PC Desktops
Master hard disk s,m,a.r.t.status bad,backup and replace
A failure message from the SMART system of this nature indicates that a catastrophic hard drive failure could be imminent. Without delay, back up ANY data you want to keep. This error isn't going to go away, and is being reported by the drive controller.
Whilever you can access the drive, move any data you want onto another media (such as DVD or external USB hard drive) because chances are it's not going to work much longer. You need to look at buying a new hard drive as soon as you possibly can, and migrating the data to it.
Files and Settings Transfer Wizard will be able to backup your data to another media.
Jun 02, 2008 | PC Desktops
just make sure in bios that your first boot device is cd rom,then install the cd and follow the instruction
May 08, 2008 | Dell Dimension 3000 PC Desktop
PC Desktops Logo
782 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
