Home | Kenmore | Elite 45986 Front Load Washer | Kenmore front loader not...
Kenmore Elite 45986 Front Load Washer
Problem for Kenmore Elite 45986 Front Load Washer
Kenmore front loader not draining.
By bethsteele20 on Jul 04, 2009
I washed a big comforter in my Kenmore front loader today along with some sheets and a few other items. When I went to check on it all the lights were flashing. I took out the comforter and left the other smaller items but found that even though the washer would spin it wasn't draining any of the water. I even tried taking out all of the clothes, but it still doesn't drain any of the water, only spins. Do I need a service tech to fix this problem?
Comments:
Jul 04, 2009
- Well, .30 and one sock later we have drainage!!! Thank you, thank you and thank you!!! Happy 4th!
Sponsored Links
Best Solution
posted on Jul 04, 2009
Very Helpful)
Maytag317
Rank: Guru  Kenmore Expert
Rating: 93%, 646 votes
Hi, UNPLUG the washer and shut off the water. Remove the lower front panel and you can access the water pump. You will need a wet/dry vaccuum to **** up the water as you open the sump cap on the pump. Spmetimes you can lower the drain hose into a bucket and get water out. Once the water is removed, open the cap and see if the filter is plugged as well as the pump inlet/outlet ports. This is common. If there are no obstructions, check voltage to the pump. it should get 120V.
I hope this helps you. Please let me know if I can assist you further.
Vic
Comments:
Jul 04, 2009
- You are welcome!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore Elite 45986 Front Load
Questions and Unsolved Problems for Kenmore Elite 45986 Front Load
Do you recommend Kenmore Elite 45986 Front Load Washer?
Answer
Answer
I have an elite calypso washer and it will not let me change the wash cycle from jeans, it also will... (More)
Answer
agitator makes loud noise during wash and rinse cycle. completes cycle and empties well. any... (More)
Answer
How do I change the front door gasket on a Kenmore Elite Front loading washer HE 3t Model # 42926201... (More)
Answer
My washer makes loud noises when turning. Noise is from the back by the pully.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore Elite 45986 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14022
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
