Question about Toshiba TN50X81 50" Rear Projection Television
Toshiba TN50x81 50 Inch TV most of the images seem to have a ghost image behind them
Any one know how to correct this? I went into the menu of the TV and tried the Convergence option to try to correct the problem but then you have to choose between some numbers and I'm not sure what these do? I don't have the manual for the TV or I would have checked that first. Thanks for any help.
  • Anonymous Dec 05, 2007
    ghost images, went to convergence menu and get no responce when trying to align the images, mostly blue color out of wack
  • indyjonez Jan 23, 2008
    I'm replying to my own post. I finally figured out the numbers and how to move the blue and red targets to match up with the white center target. What will happen is it will be fine (all colors lined up) for 30 minutes maybe an hour and then it will flick back to having the blue out of sync with the rest of the colors. I wanted to respond to Solution #1, how do I go about replacing the convergence ICs on this TV and if it is not something you recommend I do myself how much (rough estimate) would it cost to have these replaced by a technician? Thanks for responding Solution #1.
The convergence ICs are bad and need to be replaced. This is a common problem with projection TVs. These are large black ICs connected to a heatsink. Replace them and all should be well.
Posted on Jan 04, 2008
Remove the right speaker grill, there you will see some adjustemt knobs, I never tried it but might be helpfull.
Posted on Dec 02, 2007
NO PICTURE!!!! Please HELP! I am going to kill my husband for bringing this TV home!
If the model number is correct and all you can get is the menu or on screen displays to work the set may need to be reset--not on the front or in the menu.
The set has 3 hidden menus: adjustment (keep out), tech convergence, and the OPTION menu.
Option menu enables a hard reset to factory of all settings except convergence and is designed to fix odd issues.
You need the Mitsubishi remote and a 4 digit code (model specific).
If you have the remote and want to try it let me know what the actual model number is and I will give you a link to the service manual which tells how to do it correctly.
May 30, 2012 | Mitsubishi WS-55857 55" Rear Projection...
How do you fix convergence on a sony tv?
If convergence in your TV went out suddenly and severely, there is nothing you can "adjust". That's a parts failure, convergence amplifiers I.C. chip(s) went south. Needs repair! Period! Minor alignments could be done by applying "flash focus" or "manual convergence" off "menu", if available.Some models have "flash" only option. Anyway, make sure there is no large metal structures near the front of TV or large speakers nearby. that could convergence to go out. Try not to play with any adjustments, if severe convergence problem. you won't be able to fix it right and will corrupt memory settings for "flash" option.
Feb 16, 2012 | Sony Televison & Video
Need to know to set the convergence
Have you tried going to the service menu?
Do this by holding "MENU" on the TV set while it is on, then pressing "Menu" on the remote. You may have to do this a couple times for the menu to appear.
There should be a option on the appearing screen for Convergence, which has more options the the standard menu. To work this under the "9" setting for convergence, each of the + on the screen is the corresponding button the the TV remote (3 if top right, 5 is center). Use your volume or arrow keys then to move the selected + in the desired direction.
Jun 17, 2010 | Zenith R40W46 40" Rear Projection...
Tv picture went blurry and looks like two or three images on screen is it possible a bulb burnt do you change
Thats a convergence issue. Press the menu button and scroll to settings then see if the option for convergence and auto convergence is still there or has it disappeared> Then let me know and I will assist you.
Dec 13, 2009 | RCA D52W23 52" HDTV CRT TV
RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Sep 08, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Convergence Problem w/Proscan PS56670
Aug 30, 2006 | Proscan PS56670 56" Rear Projection...
Toshiba TN50X81 50" Rear Projection Television Logo
255 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
