I need the telephone number to make a repair request and send back sero 7 tablet sent to me thru miguelThe charging port does not hold a charging usb cord correctly.
If it is running S L O W L Y the most common cause is too many programs.
It has a very very limited CPU and even programs running in the background can eat up the capability.
As far as charging;
Have you cleaned EVERY contact with contact cleaner?
Is your USB port the fastest on on your computer?
How old is the battery? They do not last long
Amazon.com, Inc.
Rating: 2.9 - 22 reviews
1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
Amazon.com, Inc.
Rating: 3.7 - 6 reviews
HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
To start, gently separate one corner of the case using the black spudger.
Step 2
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
The micro usb charging port on the nexus 7 is notorious for becoming useless b/c cords fit loosely in the port right out of the box. Micro usb cords get wiggled and jiggled because of the size of the opening and then the port will no longer charge b/c solder breaks from the board, or the tongue inside the port partially breaks apart.
You can buy the replacement micro usb / headphone jack assembly for about $50 and do the repair yourself (hopefully) ...or you can send it to us and we\'ll replace just the jack and ship it back to you all for $54.95
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
These are the videos which will help you why tablet is not getting charged and solution to overcome
Try to use USB and charge it with it
and then after 10 min try to start the tablet
Depending on WHEN your tablet was purchased, you can send it back to Archos to be repaired. (via their website http://www.archos.com/support/). I have broken the pin off in mine TWICE since I got it last November and both times I sent it back to Archos to fix free of charge. They paid for shipping and repaired it for free even though it was MY FAULT! so far there were no questions asked! I have been very pleased with their customer service (even tho i have never talked to a real person they have handled the issue and I am extremely happy). there are 2 issies w/returning it however, 1. you LOSE ALL YORU DATA. they wipe it out. I tried doing a back up and then reloading it to my tablet when i got it back but haven't been able to figure out how to get it back on. 2. You will be w/out your tablet for about a month! :( Good luck!!!!!
