Sir, Iam using intel 945 mother board winxp proffissional. When staring windows audio is not comming. And in web streaming vedios only vedio is comming , audio is not comming. how to start windows with audio drivers.And audio mike icon is not comming in system tray.
just install the audio drivers correctly and then go to contol panel and look for sounds and audio devices , open that and configure correctly .. and also check this ... go to start/run and type msconfig ..in that go to startup tab , there u select he option enable all , then apply and restart your computer...your problem will be solved....
If it's an Intel board then you can get them here:
http://downloadcenter.intel.com/default.aspx
But just because it has an Intel 945 chipset doesn't mean the actual board itself is intel... it could be another sound card / chipset on the board. Make sure you check what brand the actual board is. 945 is the chipset...
please help me.. i am doing the above project for my final year in college.. if any one doing the...
(More)
please help me.. i am doing the above project for my final year in college.. if any one doing the same project ,please send me the source codes through mail.. aj_anup29@rediffmail.com
I get this ''Failed to open MCI device. Error Code: 348745'' message ever now and then. What can I...
(More)
I get this ''Failed to open MCI device. Error Code: 348745'' message ever now and then. What can I do to resolve this? Thanks, Ray
I want to set up my contacts to show journals. I tried going thru the setup of the journals thru...
(More)
I want to set up my contacts to show journals. I tried going thru the setup of the journals thru Journal Group Tab Listing...checked off the contacts that I wanted to show Journals...This did not work...Tried going into the Contacts thru ALL FIELDS once I opened the CONTACT...When I choose TOOLS...OPTIONS...JOURNAL OPTIONS it shows FOR THESE CONTACTS and it is still empty...What am I doing wrong? Also this is Microsoft Outlook 2007...
im doing fm radio i want to conect internet for listen via my web site so how to connect radio...
(More)
im doing fm radio i want to conect internet for listen via my web site so how to connect radio tansmission for internet
