Optics Logo
A
Anonymous Posted on Sep 29, 2014
How old is my remington model 6 22 cal serial # s 344101
cronked83
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 87 Answers
  • Posted on Sep 29, 2014
cronked83
Expert
Level 2:
New Friend:
Cheetah:
Answers
87
Questions
Helped
14912
Points
203
Check this site
http://www.uberti.com/1873-single-action-cattleman-revolvers
2 Related Answers
agent91
Ned White
  • 2100 Answers
  • Posted on Mar 03, 2010
SOURCE: How old is Remington model 572 Fieldmaster rifle
The serial number does not reflect the date of manufactuer, but there are letters stamped in the side of the barrel at the reciever, on the left side, they are a date code, I will give you an app, If there are more than a couple letters and numbers, it has been reworked by the factory. But none of mine have.
m=1921,,,z=1931,,, and all the letters in between there except for o and q are the years, then it starts again at A=1932, and goes to L=1942, then,,,MM=1942,,,NN=1944,,,etc to ZZ=1953,,,then it stats with A again,,through Z= 1975 and after that it a random of letters I,O, Q and V, to 1979, then A, again, to Z=2005, then it starts again. hope this helps.
strech3030us
Strech
  • 1562 Answers
  • Posted on Feb 20, 2014
SOURCE: i have a remington 22 cal model 12 serial number 187554 and would like to know the manufacture date
Introduction Year:1909
Year Discontinued:1936
Remingtons manufactured between 1921 and 1972 have a code located on the left side of the barrel near the frame that identifies the year and month of manufacture.
If yours is between 1921 and 1936, it should have two letters, one for month, and one for year.
If it doesn't have this code, it was made between 1909 and 1920.
REMINGTON Customer Service (1-800-243-9700 & follow the prompts) will look up your serial number and verify the age of your firearm.
Just to give some scope, serial number 757132 was 1929, about 569578 after yours.
MODEL 4 32 RIFLE SN# 325533 DATE OF MANUFACTURE
the following link when you fill out information on rifle will give you value and date of manufacture
http://homestead-service.com/appraisals/RemingtonModel4
Jul 07, 2016 • Optics
What year of mfg.108125 ?
Do you know what model it is?
Beings it's a .22, I'm thinking it's a Model 4, but usually those were a 22 1/2" barrel length.
1890-1933
Total production - approximately 356,000
If it's a "take-down" model, it COULD be a Model 6.
1901 - 1933
Numbers 00001 - 498,000
As far as serial numbers, a lot of them had the serial number on the side of the top tang, visible only with the action out of the stock.
Not all Remington serial numbers were consectutive for the model.
Military models were often numbered by the contract and commercial guns marked with batch numbers having little relationship to the time of manufacture.
I have a remington 22 cal model 12 serial number 187554 and would like to know the manufacture date
Feb 20, 2014 • Optics
Manual for remington rifle mod 12 22 cal pump
Go to the Remington Firearms Co. website. At the top of the page, click on Support, then click on Owners manuals. They list the Remington model 12 as one of the one's they have. It will be a photo copy of the original owners manual.
1helpful
3answers
I have a Remington rifle which is a 22 caliber octagon barrel rolling block type serial number J282433. Any info on this rifle would be appreciated.
Could use more info, such as markings on the barrel and or breach. The Remington rolling block type single shot goes back to the 1860'S. The first 22 calibers around 1888. The rolling block went through 8 changes. The different types or changes are where various pins and screws are located, size and shape of hammers and triggers. The New Model Number 4, made from 1890 - 1933 came standard in 22 cal. with a 22 1/2 inch Oct. barrel. It will have a small lever on the right side of the breach. Approx 50,000 of these where made between the years noted. You could very well have a model 1, 2 or a model 7, which will be rare if in very good shape as only 1000, No. 7's where made. Tracking the serial number will be hard unless you contact Remington.
Oct 30, 2011 • Optics
2answers
Renington shot gun have serial # and want date the gun was made please remington wing master 870 serial436894
How can I tell how old my Remington firearm is?
If you will call or email us the serial number and model number we can determine the approximate age of your firearm.
Serial numbers were not required until 1968. For models without a serial number, we may be able to determine the age by the 2-3 letters that are stamped on the barrel.
Contact us through our Help Center by email or call us at 800-243-9700 Mon-Fri 9-5 EST.
email [email protected]
3helpful
Where is the serial number located on a remington model 37 rangemaster, cal,22 rifle?
693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
Ending: 12300 Grades Offered: Model 37 Rangemaster
37 Target
37AR
37AF
37AX
37AM
37AV
37AS Variations: None
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
