Only the switch at the back will shut it off. Did you figure out why yet?
Comments:
Jul 04, 2009
- I do know the switch at the back is the main power switch but when this machine was new, the main switch at the back could be on all the time and the motor that runs the plunger would not run continuously. But now it does. I am leaning towards the little button switch on the circuit board behind the big Black Start stop switch on the front being faulty with a closed circuit.
When the coffee maker reaches temperature and the ''Coffee Ready'' light comes on, steam is...
(More)
When the coffee maker reaches temperature and the ''Coffee Ready'' light comes on, steam is discharged into the drip tray via the pressure relief valve and tube assembly. When coffee is made, the water quickly loses temperature and the ''Coffee Ready'' light goes out. I have recently descaled using an appropriate coffee machine descaler and the problem started thereafter. I suspect that a seal in the T-valve has failed, but I don't know why. I have dismantled the machine and inspected the boiler - the element is ok. What appears to be happening is that, as the water reaches temperature, the steam generated is forcing its way back along the pumped cold water supply line, across the T-valve and down the pressure relief tube. I guess the solution is to replace the T-valve, but why should the seals be damaged by the descaler? Is this likely to happen the next time I try to descale?
The motor just keeps running after the coffee has completed it's cycle. The only way to shut if...
(More)
The motor just keeps running after the coffee has completed it's cycle. The only way to shut if down is to turn off the unit. I've tried descaling the unit but that has not helped.
I appear to have lost the part that pierces the discs for my machine think it got stuck in a disc...
(More)
I appear to have lost the part that pierces the discs for my machine think it got stuck in a disc and has been thrown away by mistake? please can you help and tell me where i can buy a replacement spare part
