Home | Frigidaire | GLTF2940ES Front Load Washer | Water will not drain dur...
Frigidaire GLTF2940ES Front Load Washer
Problem for Frigidaire GLTF2940ES Front Load Washer
Water will not drain during spin cycle
By budgirl_8_3 on Jul 04, 2009
hello! when i wash a load of laundry (admittedly, I am new at using this machine and can't find the user's manual), the water does not drain out during the spin cycle. what am I doing wrong? I'm not a blond, I swear. Just need some help... :o)
Best Solution
posted on Jul 04, 2009
Very Helpful)
Maytag317
Rank: Guru  Frigidaire Expert
Rating: 93%, 650 votes
Hi, You might have a plugged pump or even a bad pump. UNPLUG the washer. Remove the lower front panel and locate the pump. You might need a wet/dry vaccum and **** as much water out as possible. Remove the hoses from the pump. AGAIN, have the vaccum close to **** up some water. Once the water is gone, look inside the pump ports and see if there is anything blocking it. You might have to check voltage to the pump motor to make sure it is working. The motor should get 120V to the wire harness at the pump.
Please let me know if this helps or if I can assist you further.
Vic
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 06, 2009
Not Rated)
pfrasquieri
Rank: Guide
Rating: 80%, 3 votes
don't forget that inside the washer (must remove the tub) there is a drain hole which feeds the pump (hose connects from the tub to the pump). There may be a clog there as well.
Secondly, since you said the spin cycle, I will need to ask if your are sure the spin cycle is working?
If so then its the water pump pump.
If not then it could be a motor (if the motor agitates the tub then the motor is fine), the clutch mechanism or gearbox.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire GLTF2940ES Front
Questions and Unsolved Problems for Frigidaire GLTF2940ES Front
Do you recommend Frigidaire GLTF2940ES Front Load Washer?
Answer
Answer
Don't get any error code, but still doesnt' spin. The washer is only 2 years old, ran fine until... (More)
Answer
it will go thru the whole cycle of washing and when it trys to spin it out, it won't. it will spin... (More)
Answer
Does not spin says there are 7 minutes left in cycle then stops completly
Answer
My frigidaire front loader seems to be making a electrical humming noise on the wash cycle. Is that... (More)
Answer
Frigidaire GLTF2940FS...does not do a final spin/clothes wet. it is draining just not spinning. No... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire GLTF2940ES Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
