Question about HP PSC 1410 All-In-One InkJet Printer
Printer when plugged up lights come on then they go out, no power do i need a new power module?
  • 82 Answers
Attach the control panel overlay (bezel), if not attached...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00316871&cc=us&lc=en&dlc=en&product=441115&dlc=en&lang=en
Posted on Nov 16, 2007
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
My printer won't turn on
Hi
Either the power source has issues or the power jack on printer has gone bad or printer's main board has issues.
Verify that the electrical connections and outlet are functioning:-
Unplug the power cable or power module from the electrical outlet.Unplug the power cable or power module cable from any power strips or surge suppressors.If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.Unplug the power cable or power module from the back of the product.Wait at least 30 seconds, and then plug in the power cable or power module into the electrical outlet.Plug the power cable or power module back into the product.Turn the product on.
If this doesnt help, take the printer to another room and plug it in another power source.
If this doesnt help, use a multimeter to check if adapter is giving out right voltage.
If adapter and power source are fine, then your printer has a hardware issue and needs to be repaired by Canon.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
My hp f4280 printer don't have power to on.
hi misssim31, if the printer is not turning on..there might be a possibility that the power module is already faulty. if the power module light is lit up (the green light on it) try to plug the cord into different wall outlet and if it didn't worked..change the power cord and the module..and still if it didn't worked then the port on the back of the printer where you plugged the power cord is no longer working.
if you have any further question..dont hesitate to reply..
thanks
May 29, 2011 | HP DeskJet F4280 All In One Printer InkJet
3210 printer won't respond!!! I cannot print out anything on this printer, but it was working one month ago!?!?!
Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Apr 07, 2010 | HP Photosmart 3210 Printer
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    4. Wait 15 seconds.
  • Apr 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    Wont switch on
    Solution three: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    4. Wait 15 seconds.
    Apr 07, 2010 | HP Photosmart C5180 All-In-One InkJet...
    No power on the machine,despite th light on the supply showing green,as soon as the power lead is plugged in,the light goes out
    is it plugged into a wall out let or surge protector?
    try a different out let all together if the same thing happens then the unit is pooched. if the led light is going out on the power module then the module needs to be replaced
    Mar 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
    My 2350 all in one will not turn on.
    I'm not sure if this is a solution, but it worked for me. ( who knows how long it will last, but its working for now)
    Below are the steps I took:
    - uninstalled all the HP drives and software
    - unplugged the USB cable from the computer and printer
    -unplugged power supply from the outlet and printer
    -plugged the USB back in to computer and printer
    -unplugged the power supply from the power module. Made sure everything looked ok,
    -reattached power supply cord to module ( Made sure everything looked ok,)
    -plugged power supply in to outlet ( green light was on)
    -proceeded to plug power module connector to printer. ( again, making sure proper connection was made.
    * this time the screen came with an error and the "on" power light was blinking.:
    This was the error message:
    Error:
    0xb9000009165:
    hw_interupt_hwv.c
    -I proceeded to unplug the power and usb from the printer
    -downloaded the lastest drivers and software for the PSC 2350
    -After the software was loaded and installed ( I checked the box to install with out USB communication at this point)
    - plugged the power and then the USB.
    -It came to life at that point. (the computer recognized the "new" product)Going through what I presume were several realignments or internal configurations.
    I tested a page, and ran the HP Dinostic's page. Everything checked out, and its running fine for now.
    I hope this may have given you some ideas as to fixing your printer.
    Feb 14, 2009 | HP PSC 2350 All-In-One InkJet Printer
    HP PSC 1410 All-In-One InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
