Question about GE 30 in. JP340 Electric Cooktop
Burner always on high
My front right burner always heats to high regardless of what I set the knob to. Happens on both the large and small setting. Any thought on how to repair myself??
    Welcome Back:
    Visited the website for 2 consecutive days.
Re: Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Posted on Mar 16, 2008
0 characters
3 Points
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
Sep 23, 2011 | GE Cooktops
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
GE 30 in. JP340 Electric Cooktop Logo
738 people viewed this question
Top GE Cooktops Experts
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a GE Cooktop Expert? Answer questions, earn points and help others
