Home | Frigidaire | FRS26R4A Side by Side Refrigerator | Water collecting and fre...
Frigidaire FRS26R4A Side by Side Refrigerator
Problem for Frigidaire FRS26R4A Side by Side Refrigerator
Water collecting and freezing in bottom of freezer
By jarriaga7531 on Jul 04, 2009
Water is leaking out of back of freezer (inside) and freezing on the bottom (below bottom basket) creating a sheet of ice which then leaks out onto the floor when defrost mode kicks in. Any idea what's causing it? Thanks!
Best Solution
posted on Jul 04, 2009
Helpful)
Maytag317
Rank: Guru  Frigidaire Expert
Rating: 93%, 648 votes
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Frigidaire FRS26R4A Side by
Questions and Unsolved Problems for Frigidaire FRS26R4A Side by
Do you recommend Frigidaire FRS26R4A Side by Side Refrigerator?
Answer
Answer
the water paddle broke off and need help to replace a new one
Answer
fridgedaire frs23lh5db1 ice maker not working. this fridge is used and when i got it the green... (More)
Answer
wHERE IS THE POWER BOARD? THE FREEZER AND FRIDGE ARE DEAD BUT I HAVE POWER TO THE RELAY i CANNOT... (More)
Answer
no electrical power to icemaker and water dispenser on Frigidaire Model FRS26H7CB4 side by side... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FRS26R4A Side by...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
